Kooks Headers install
No silicone on the heads or header mating surfaces either right, just the gasket?
unless you pull the engine you’ll never get a torque wrench on those bolts
I was wondering what it should be so I can torque something to that spec and get the feel
Thread Starter #44
just the gasket
These headers are hooked up to the exhaust system. Does anyone run open headers?
Alternator off. All coil packs off. Wires finally up out of the way
curse the engineer that put the oil pressure sensor (green plug) in that same loom of wire. Past me didn’t lock the white sliding lock clip when I put it back on the last time. Thankfully. Only reason alternator needed to be completely removed was to unplug the oil pressure sensor behind it so that the group of wires could be moved out of the way
