Getting off the line. Help!
Tazer/burnbox will not cut any power when it goes to street mode. It effects the shifting and suspension. I ran the same time when I didn't change it back after a burnout. It's is one more thing to do but once you do it a few times it becomes habit after your burnout. My line lock out weighs the one extra step. @jonx96 was at the track a few weeks ago without line lock and it effected almost every pass not getting a good burnout in
D
Demid22
Nurse
JONESBOROUGH
2017 Dodge Challenger Hellcat
Thread Starter #42
Possibly a catalytic converter overheat.
Forgot to add to my mod list. Im running catless mids.
Here are some high 9 sec times slips. This will give you a look at the mph necessary to run high 9 sec et’s This was done on a well prepped track and I was running 3.09 gears with the 17” 315’s at that time. DA777280-DB3B-4999-A3A7-5185E05B6DD2.jpeg
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #44
I know i need to work on reaction time but from my understanding that doesnt effect my et or 60ft. Yea ure getting 1.4 60.ft. That's where i should be but cant seem to get it there thus the thread.
How's the prep? I watched a little of the street car shootout or takeover and they were basically no prep racing. Prep was horrible.
You need more out the backend in my opinion.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #47
Its decent. There's other cutting 1.4 and 1.3 60ft.
Hell less modified hellcats and scatpacks are getting out of the hole better than me. I just dont know what im doing wrong,
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #48
What do you mean by this exactly
I used to index race and liked to chase.
time slips will help to look into further. Is your car really heavy? We all weigh in the same area but have seen some cars pushing 5k. Are you sure the diff is working correctly? Some have said the clutches are worn are not holding well so one tire may be spinning some
2.5 pulley is slowing you down I bet. Many have tested and below 2.75 it gets too hot. Your coolant tank may help but I'd be curious what IATs are like.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #52
Ill ask jon my tuner. Ive got the interchiller stage 2. When im coming off the line my supercharger coolant is 30 degrees. The 1.5 60ft is slowing me down too
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #53
Diff seems fine.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #54
I can try a fluid change. And see what the old fluid looks like. Its about a year old.
If you think it is working fine then I'm sure it is. Just throwing ideas out. Have you sent Jon a datalog of a pass at the track? Something maybe happening on launch
Should launch awesome with that pulley but get what you are saying down track
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #57
Yea i sent him many many. I. Log every pass. Nope doesnt launch well at all
So is it spinning or not pulling
Jon-MooredPerformanceLLC
Martin
2018 Dodge Challenger Hellcat
I sent a second gear
youll have to try and reupload when I logged in this morning they weren’t there
Martin
#60
I uploaded a second gear launch tune and a soft launch tune. Can try softer but on your tire you shouldn’t be having issue
