Lip on rotors
Front rotors have developed a pretty deep lip. More on the inside of the rotor than the outside. Can they be turned down? What is the spec? I have calipers, I'll measure thickness with lip, how deep the lip is, and then subtract the lip. Is this the correct procedure to get the thickness? Does anyone have the spec so I can tell if they're able to be turned? Thanks
Hellcat
For the Dodge Hellcat (Challenger/Charger SRT Hellcat) front rotors,
34 mm nominal thickness
32 mm minimum service thickness
OEM Pad Thickness
Front Pads:
Brembo P37018 (15mm thick, 93mm height) Semi-Metallic, Performance
Brembo P37018N (16mm thick, 93mm height) Ceramic, Dust Reduction, Non-Asbestos Organic (NOA)
Rear Pads:
Brembo P11024 (15mm thick, 69mm height) Semi-Metallic, Performance
Brembo P11024N (15mm thick, 69mm height) Ceramic, Dust Reduction, Non-Asbestos Organic (NOA)
I vaguely recall reading somewhere that Dodge recommended against turning these rotors (2 mm is not much to play with) - but I could be wrong.
@BULL any thoughts?
@BULL any thoughts?
Turning is ok in my mind, IF you can find a shop both willing and able to successfully do it.
You need a knowledgeable tech, sharp tools, and hat hardware in good shape to prevent chatter.
(if the ring isn't securely attached to the hat, it's going to chatter, unfortunately rings that need to be turned tend to go hand in hand with degraded hat hardware.)
The good news is that hat hardware is now available and can be replaced, unlike in the past where it essentially wasn't available.
Also, understand that even if you're at say something like 32.5mm (.5mm over min), there may not be enough to turn without going under the 32mm min.
And a bit about rotor min thickness, which I didn't learn until not all that long ago...
The FIRST reason that this is a concern ISN'T rotor thermal mass capacity (although that IS a secondary issue), the first reason is the caliper pistons are designed for a maximum extension.
So you have to consider min rotor thickness, AND min pad thickness, resulting in a maximum piston extension from the piston bore.
Further with our rigid calipers, this is further compounded if there is an asymmetry in either and/or the rotor and pads, unlike a floating caliper that can tend to find center of the system.
Hellcat
To that point:
For 6-piston Brembo front calipers (as used on SRT/Hellcat/Redeye/Demon), the maximum safe piston extension is about 8–9 mm. Anything beyond 10 mm is considered unsafe.
Three piston pairs
Usable/normal travel: 4–6 mm
Maximum safe travel: ≈8–9 mm
Absolute danger zone: ≥10 mm
Absolute rotor minimum: 32 mm
Caliper-travel-based pad minimum (rotor at 32 mm):
  • ~7 mm friction for P37018 (starts at 15mm)
  • ~8 mm friction for P37018N (starts at 16mm)
U
Mine are too far gone, have a 2.3 mm lip just in the inside and 1.3 on the outside.
has anyone used the new power stop 1 piece replacement rotor for the front? Probably heavier but for 1/4 the price might be worth it. You're stopping a 4700lb car from high speeds I don't care what rotors they are it's going to be hard on them
has anyone used the new power stop 1 piece replacement rotor for the front? Probably heavier but for 1/4 the orice might be worth it
2 things I never consider PRICE a factor....tires...and brakes...EVER...EVER...EVER..
The Englishman
Newbury
United Kingdom
2018 Demon
Back in the day i used an angle grinder to remove the lip on rotors and brake shoe hubs on a regular basis.That was until a brake pad left its assembly and ended up on the asphalt, van stopped fine on the brake piston luckily.
A few months ago I took off rotors that measured at 30mm thickness, could still see the slot but could barely feel it with your finger! Pads still had a lot of thickness on them though fwiw.
Tagging @BULL so he can scold me ;)
Geeze don't tell UnHoly Guy that...I can see it now...angle grinder in one hand...and a sledge in the other..good God
The Englishman
Newbury
United Kingdom
2018 Demon
Felt like someone was watch me.
You can theoretically get away with this, IF you keep new pads on it AND don't want to do anything like road courses.
However even if that is true, it still means you're a bad person. :oops:
As a side note, this very scenario is one of several reasons why I can't get CDT rotors to pass DOT testing... :(
Wtf...ya ben workin on this forever....here's the key to DOT certification...(bribe them...with REAL cash...or just threatin them with bodily harm)....it's always worked for me..:giggle::giggle::giggle::giggle:;)....(oh wait I forgot...yer not an Italian):oops::oops::oops:;);)
Well, here is the REAL problem...
I actually care about my customer's lives...
And I care about their cars too...
:p
:p
Not to worry...(offer them enough they will take the money);););))
You....follow too many rules..:oops::oops::rolleyes:
On my office door I had a sign..."CHAOS" CO-ORDINATOR"......and on my desk..."we got no rules here..were tryin to get somethin done"
Guess we don't see things he same way...(which is ok)....
I'm selective
