Not sure where to post this particular question
With the transmission not turning, there's no reason for the fluid to get cooled.
Jimmie...does us all a favor...put in a wake up call to the Unholy guy...every hr on the hour:rolleyes::rolleyes::giggle::giggle:;)
IMG_5866.jpeg How many modes does the transfer case have on a TRX? Single speed transfer case CAN NOT be flat towed.
Only if you can set the transfer case into neutral can you flat tow. Period.
My Durango is RWD, so cannot be flat towed. Period.
Without going out to look, I'd say there's normal high range AWD, high range 4WD, Low range 4WD, and Neutral.
More than enough to allow flat towing.
hopefully was done correctly
Was looking into a weight distribution hitch for my jalopy and was flipping through the owners manual and saw that
All my posts are done correctly.
More or less.
You can disagree all you want @1971demon. Those are facts 😉
You seem to get yer giggles disagreeing with an inordinate amount of my posts...just returning the favor...get used to it...
Usually just when you ramble 😉
I used to flat tow my Jeep, with freewheeling hubs on all four.
Then I found out about something called trailers. They are absolutely great for towing vehicles on or in.
What’s a trailer?
What’s a trailer?
It's like those pesky tailgaters, following your speed and every move.
Except in a useful way.
