Getting off the line. Help!
May have spun the coupling on one of the shafts. I saw a similar thing before if failed totally running a 2.72 upper and +10 lower.
I haven’t had a chance to look at your logs is the bypass valve voltage where it should be? It could be getting blown open, had that happen too.
Bypass at one point was opening. He ordered a new one and now it has been good to go. There is a chance the throttle body is sucking closed now.
D
Demid22
Nurse
JONESBOROUGH
2017 Dodge Challenger Hellcat
Thread Starter #242
I thought we did a few tb logs and determined it wasnt?
I’m just going off what speedy said above. You say throttle is cutting out. The quick view when it first came in throttle torque source never changed. I haven’t looked close enough at these ones
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #244
Oh. Ok. Gotcha
Same thing happened to me if you remember, had to step up to a Nick Williams TB and it stopped doing it
If the throttle was at fault at all the car would go into limp mode and red lightning bolt of death. Just my .02, something is commanding the throttle to close is more like it.
$.02 The ECU is likely commanding the throttle to close because the throttle body motor isn’t strong enough to stabilize the blade at WOT. Increased airflow over the blade can cause it to move if the motor holding it open isn’t strong enough. The TPS will detect this instability and report back to the boss who says game over. This was a common problem back in the day with the Whipples. Nick Williams and others started using more powerful throttle body motors to address it. If the tb is a cause then, just like the bypass… try another one.
I could see the argument if this was 25 lbs of boost but it is 15 lbs. Can the throttle body go bad where it will not hold which it did before? Maybe OP could borrow one to test instead of buying one
Maybe a silly question, but since you still have the stock lower I thought I would ask - it is pinned, right?
That’s what I would suggest. You’re right he’s not flowing enough air to normally have this be a problem but if it’s acting like a duck you should at least try treating it like one to find out.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #251
Lower is pinned. I ordered an ati 10 lower and a 2.72 upper last night and a new belt. Gonna try swapping it around and see what we get. Additionally ill do a few more logs and test the tb more.
Considering in going whipple in the future I don't feel like buying a tb for the 2.4l blower when in going to be using that monster 130mm on the whipple
Could also be bleeding boost with a stuck valve or other motor issue.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #253
Bpv is closed
I think he is implying a valve train issue.
Intercooler cores don’t ever get clogged on these right?
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #255
Ah gotcha. Well i spoke with Jon today. Weve been hammering away at this for a month trying to chase it down. Gonna step away for about a week while parts come in. Ive got the ati 10% lower and 2.72 upper to install along with a set of LT headers. From there we will reasses after the install. Track day is 17th so hopefully i get everything in and on the vehicle for that.
Murfreesboro
2016 Hellcat Go Man Go
What's the elevation where you are? I see your in TN a few hours east of where I am. I've noticed in your logs your barometric pressure has shown 13.8psi, mine is always close to 14.7 which is what I'd expect. If you're around the mountains that could explain the difference. I'm at like 600ft elevation.
The reason I mentions this is it more evidence (for me) that there's really nothing wrong supercharger/engine wise. Your baro is a bit lower and you have catless mids and that would explain the pressure difference. Catless usually drop actual boost 1-1.5psi I believe. Your aircharge looks pretty normal.
The throttle thing should be sorted out though. That's not typical. I have had throttles fail on me before, and it acted up a bit prior.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #257
Bristol TN - 1676ft
And if everything is checking out and looking good on that end... Im happy. All of this started from some of the more knowledgeable memebers seeing my mod list, track slips, and dyno slips and stating I should be faster (1/4 mile) or more power (dyno). Thats why i keep chasing down this rabbit hole, because that's got me thinking something is wrong.
Murfreesboro
Every +1000 feet of elevation is usually worth 1/10 in ET and a MPH or two. I think initially someone else had tuned your car, and you switched to Jon. I'm sure he has the tune pretty well squared away aside from the trims he's stated he'll finish once you're all sorted pulley wise.
You probably listed the DA for your track runs and I've forgotten what that was. My car with a 2.72 pulley and E85 trapped around 140mph in +2000 DA. That's with a rear seat delete, and drag pack wheel/tire setup. Race weight with me in the car like 4250 I think.
D
Demid22
Nurse
JONESBOROUGH
Thread Starter #259
Anything in this thread has been with Jon. I did have someone else tune it originally but it wasnt that great so Jon stepped in and made it nice. But everything posted in this thread has been with Jon
Murfreesboro
Here are some of mine to compare. I've got the RE motor which has a different cam but this was a 2.4 Hellcat blower and 2.72 pulley on E85. Weight with me in it 4250ish if memory serves.
