Trying to hook 9 of 10 times. Not 1 of 10
Hatermkr
West bend
2016 helldemon
246FEAE6-0BA8-488B-80F4-15C6A8EAC770.jpeg 53C08A37-A6DD-4E83-A184-15EA6DA0AD64.jpeg 5CF6B56D-C1FF-4C0B-8788-F6C708F051AF.jpeg B9520566-E8DF-4CB3-8ADD-B63FDF347B3D.jpeg
Hatermkr
Hatermkr
West bend
2016 helldemon
I like! All of the electronics are out of this car right? Wonder if I can disable the active suspension and switch to these
Yes shock delete engineering makes plug In adapters to keep light off
Ah no way really? Good to know. Let me know how these work after you dial them in
How much total weight did they shave off the car too? You remove the rear perch springs with these right?
Hatermkr
Hatermkr
West bend
2016 helldemon
Was about 30 pounds total front and rear yes you loose the rear springs. Going to be a bit I’m putting in a cage also and my 3.8 whipple
$600 for the sctiver dampener delete is insane. I wonder if you can just shut it off with Alfa
Hatermkr
Hatermkr
West bend
2016 helldemon
I could for 4
zhc
2016 Dodge Charger Hellcat
Yes you can. I totally forgot that’s what I did on my car once i switched out all for shocks.
Exactly the answer I was looking for Z, thanks for confirming!
zhc
It’s mislabeled in AlfaODB, I’ll look for it later tonight.
zhc
Ok maybe not tonight, I couldn’t find my notes on it and my car is already loaded up in the trailer for an upcoming trip
No worries! I’ll keep an eye out for the information though, would definitely like to see what needs to be changed. Thanks man!
Hatermkr
Hatermkr
West bend
2016 helldemon
What’s this Alfa you speak of?
I used it to configure my car for the a8 swap, allows you to reconfigure the BCM on the car and add/change electronics/parts/car configuration
And I’m always willing to share any info I have, very powerful software. Does things even witech can’t
Also use it to turn off my TPMS for racing, and started tinkering with turning off airbag light for removing sats, but I have modules for those
Hatermkr
Hatermkr
West bend
2016 helldemon
Thread Starter #19
Never heard of it
Useful tool but can screwup your car if you don’t take a backup of its config
