Trunk latch
Demonic Cat
Same problem I had with my last ride. 17 HC Challenger just before I sold it. I replaced the whole latch, as I remember it was hauling down the voltage when fob button pushed replaced the whole latch, it was cheap in 2019, me thinks like 40 some odd can’t remember exact.
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Yeah... I'm thinking more and more, either short to ground, or losing ground (open ground circuit).
Sent from my SM-G666 using Tapatalk
Demonic Cat
Doe No. his case could be different situation, mine must have been some kind of short, it was a hauling down power, as I remember there was very low/partial voltage not full when fob pressed. I think the old part i put back in the Mopar parts box I bought and out in the garage, I hardly ever throw stuff out. I‘ll check if I still have it. If I do maybe crack it open, see what failed.
What is it w mopar? Isnt trunk latch technology pretty much established now? It just seems to me that this is wayntoo complicated.
Jon,
I sent a text to Fnkychkn he is not a member here but was at the other place and he is a long time MSHS racer too.
He said check fuses 6,7,8 & 9 in rear PDC.
Linda :)
Thread Starter #48
Jon,
Linda :)
Thanks I checked 6 and 7 but not 8 and 9. I think I am going to purchase the back button and wiring harness that goes with it. Out of ideas
I hope it is one of the 8 or 9. Pete is a knowledgable guy and has always been pretty much right through the many years of helping the Hemi Guys with electrical problems!
Good luck @jonx96
I’ll fix it for you for a trans tune?
Good luck @jonx96
Does the car think the trunk is not closed when driving?
Thread Starter #52
It knows the trunk is closed. That is the same wire as the trunk light and that works
You 100% sure the latch solenoid has a good ground?
2fast4u
Edwardsburg
It sounds like the interlock,(read switch inside latch), is not telling system it is fully closed so it won't allow it to activate....
But wouldn’t that set off the trunk ajar light?
