"Project Demons Breath"
Thread Starter #241
LOGS SENT ,car ran great tonight no issues at all and as you will see in the logs no kr either
I will look at them as soon as I home
is yor iat the same that's in the performance pages?
Thread Starter #243
Looking at the channels you sent me I would think you need to log:
Cylinder Airmass
Total Airflow
Aircharge
and compare it to:
Desired Engine Airflow
I'm going try and log every airflow and temp log I can
Thread Starter #244
I don't remember at the moment lol . I will test this weekend and confirm.
I log all three of those total airflow,air charge and cylinder
Thread Starter #246
Good stuff . I think I'm going to try and get as much data as I can every time I test a part or combo.
total airflow I see is 134.34 lbs/min
air charge 1,635.6 mg
cylinder mass 1.65 g
motorhead
Ottawa
2019 Challenger HC Widebody
Right. So what? Well, the numbers for a stock setup would be a good baseline for any changes made. This has been my point since you poor bastards found me (or I found you). With respect to intake tubes, IATs alone are meaningless - if the air mass (lbs/min) go up and IATs (*F) go down there is a benefit. This will most likely be reflected in trap speed. If there are no significant changes in air mass, and IATs drop a negligible amount - the advertised benefits are moot.
The next point that needs attention is dropping "boost" as a concept of performance measure. the real tell is always air mass. At sea level or 5000 ft you will definitely see a measured deviation in air mass - where "boost" (a measure of restriction, not quantifiable air flow) remains similar.
The factory ECM may actually show the effects of air mass increases based upon its internal calculator by way of the torque/hp gauges.
Long story short this should be summarized as: Adding such and such intake tube netted me a peak/average increase/decreae of XXlbs/min air mass and a drop/gain of XX*F IAT, and +/- X mph in trap speed.
:unsure:
Thread Starter #250
I'm going to Naperville Oct.13 . I'm going to re run the tests with more data points in my vcm scanner . I am now curious on what's going on inside the engine and what it is telling me when I change intakes . In my opinion for my engine it's the volume increase that helped the most . I truly don't believe the stock air box has the volume to support my engine now .
Damn Mo to Head. They must have found us both at the same beach bar. Easy on the caf ine. Try sum mo to Joe instead. I test mine beers per hour. Funner that way. It's like me, myself, and I having a conversation in a 2 way mirror. Better that way. No arguments is what this tread is going towards. A bit of hoo moer in tised would be a Key West way of life. I, myself, just try and piss off, or on, the stang gu ruse for fun. Kinda takes the edge off the morning hours,,, when THE DAMN SCHOOL BUSSES PISS YOU OFF. Take a Xanax and a bit of Buff hay and chill. Take a deep breath of nitrous.
@hellno, what was your IAT after the burnout and what was it at the end of the 1/4?
What was ambient temp?
Aircharge confused me for a while. I kept thinking it was related to boost, but it's not. You'll notice aircharge will actually drop in the upper RPMs. My max aircharge was about 1750 in the 93 degree heat logs. Pratio of 2.2 (this is boost).
I recommend having aircharge, pratio, and ambient air temp in all logs.
However, I've found having too many PIDs in the channels list will cause the reading to lag big time. I thought I was having a trans shift issue the way the RPMs would round over instead of go to a sharp peak, and it turned out to be a lag and I had to remove some PIDs.
Thread Starter #253
I'm going to ATCO Nov 1-2 for the modern Hemi shoot out . I hear a lot about this track so it's time I find out for my self.
You'll have a good time. Good bunch of folks, don't be afraid to just walk up and introduce yourself. Never been to Atco, but apparently it's from outer space and amazing times are possible LOL.
New jlt installed getting ready to install the cat deletes
@Speedy I sent you an email with the log from last night should show the info your looking for 8A14BDF4-AFFA-49C8-B90B-A6A4BAF4D730.jpeg
Thread Starter #256
@Speedy I sent you an email with the log from last night should show the info your looking for View attachment 3274
Shiny !!!!!!!! I want more logs lol .
I wonder if placement of the maf sensor is causing the iat to get cooler ,if it doesn't then id say because my stock blower is being spun at a faster rate now with the pulley change then its just creating more heat
Thread Starter #258
I'm not shy. I'm sure after this weekend there may be a story or two about me lol
Cool fall air and a track elevation of 88 feet above sea level .... We shall see .
New best first pass tonight , stock airbox 96C17C80-43D2-4D1D-ABB8-292AB062452C.jpeg
Thread Starter #260
