Turning on torque reserve on a 2015 Hellcat.
Thread Starter #21
Fast forward to how this story will end, as what you seek has already been done. The biggest issue is the 28" tall bias ply tire and 2015 do not have the ability to set LC in 100 rpm increments down to 1k. I tested this on a 28" radial on my 16 hellcat. You may be able to get LC to work, but leaving on boost aint gonna happen without smoking the tires or pushing through the beams.
Would prep and PSI make a difference? I run 15PSI on my tires when I get to the track. MIR preps pretty good. I think I might be turning too many knobs at once. I'm going to leave well enough alone till I have more time to tinker with it. I did notice that the Demon tune column's axis and values are more aligned with a 2015 Hellcat Stock Tune than the 2018 oddly. I did try with .25% of the demon numbers and it didn't make much boost. I think that's because these cars don't really start making boost till higher RPMs and if I set it high enough it will just push through the tires.
Murfreesboro
2016 Hellcat Go Man Go
As for tips practice is a big one lol.
These cars will typically make max boost as soon as the throttle hits the floor. It's a PD blower after all.
Thread Starter #23
I don't disagree. Maybe I'm asking for too much. Maybe I should just do the deed and get injectors and a pulley finally. I'm going to shelve this topic as it was fun but I don't want to break anything. I have a DSS drive shaft to test first and look forward to using that while on LC, that way I don't have to worry about shocks to the system. It's always fun to be inside HP Tuners tinkering.
Murfreesboro
Good on ya for experimenting. It seemed to me if LC worked or there were ways to make it work we'd hear more about it but consensus has been foot brake is the way to go.
Murfreesboro
Oh, here's a pic of my first attempt using launch control. Bone stock. After this I figured it was a gimmick. I let out when the speedo read 70mph and I was literally doing 20.
Thread Starter #26
I guess im spoiled, track prep where Ingonis decent and I’ve never spun. Also hit my 10.8 using LC. Saw your most recent video, what was the hint you got to make the car leave just right. I’m looking for a better 60ft :)
Murfreesboro
Stuff I figure out on my own I share. Stuff a pro tuner tells me about I don't share. I suspect all the professionals know about it though.
Most of the reason I havent shared my file with anyone. Certain public knowledge or parameters yes...but I'm not about to send Curt's work all over the internet. Any question I've ever had he's answered honestly and any required change happens in under 24hrs. Not gonna do him dirty like that.
I may pay up for some track support in the spring so we can get some work accomplished on the short game.
Murfreesboro
Curt for sure knows how to make tunes for launching the car. He and I talked about it in person at ChallengerFest after Mike set mine up. It's a slick setup and easy to quickly change for conditions. I had been re-writing the timing map in the lower RPMs and this is way easier.
LC has always been a waste of time, though I have heard some folks say they have gotten good use out of it at the track. I personally feel it is a major failing of the car - it has all the sensors and software to do a top flight, highly reactive, launch control that would lay down good numbers for the conditions 75-80% of the time for any driver (and likely assist those who are already good achieve more consistent results). But its current iteration is almost like it is an after thought. I was a little less offended when the GT500 also turned out (for most users) have have a launch control that was not all that great either.
Thread Starter #31
100% agreee. I share my information cause I'm a newb and want people to stop me from grenading things. Based on the video I thought it was a tire pressure change. Didn't know it was in the tune. Which was also why I asked for the stock tune in all instances, didn't want to steal anyone elses work. Wanted a good starting point to move from.
Murfreesboro
No worries. It's a tune setting which kinda surprised me really.
The C8 has obviously figured out launch control. Wish these cars had a system like that.
Thread Starter #33
After doing a post on the HP Tuners forums the bouncing of the wideband is acceptable. Launch control is basically causing misfires to get the desired effect.
swatdocsc
Law Enforcement
Jefferson City
MO
I have been doing tests on my 19 RE using LC and since getting the H/O kit I have been logging said test different temps tires road surfaces I'm finding at 1000rpm setting 100% of launches thus far 10+ have been sub 4 sec 0-60 with the bfg g-2 y-rated it was 3.8-9 with the last 2 with the r888rs its been 3.6 3.4 respectively. this newer LC is definitely not the LC I had on my 16. I'll give more results with some other parameters i'm testing mind you these test are not on a preped track just a normal road surface.
Original LC was pure garbage.
Murfreesboro
When I get a minute I can compare 2016 to 2020 and see if I can find any differences.
swatdocsc
Law Enforcement
Jefferson City
MO
as soon as the new g tech arrives I'm going to make this a bit more scientific.
I have been thinking about playing with the launch control. Did you ever get this to work for you? I have a few settings I want to try but with it being winter I can't do a whole lot of testing.
Murfreesboro
Yeah it works. Compare to a RE for starters. I've found the process to complicated to use in a race at the track though but might experiment shooting for a PB in the spring.
I’m looking at the demon now for comparison and ideas. I figured it’d get me in the right direction. Glad to hear you got this working.
