Track Night 5/29/20 - Good & Bad
I only got in 2 passes at HRP & the DA started at 2119 & was 1963 on last pass, 10.31 & 10.27 , I was at FULL weight except for the rear Race Stars & DR's with 5/8 tank of gas.
No more skinnies ( stock wheels & tires on front ) & no front seat delete or anything removed from trunk. So that's all good but on pass #3 , about 4 cars b4 my turn I'm hearing a clicking noise like a rock is in the Driver side DR tire , so I jump out to look & maybe get the rock off but it was a big headed sheet metal screw in it , I don't mean a little screw , it was pretty big , so I didn't want to make that pass & take a chance of it coming out on the burnout & going flat 1/2 way down the track. So I pulled to the side & wasn't sure how deep it was in tire so I had my multi tool that has pliers & pulled it out & pssssssss , oh shi* , I stuck it back in the tire & aired up & took off home , I was watching the tire pressure gauge on the dash & I barely got on the Freeway & the air pressure was dropping fast , screw came out , had to pull over & used the tire sealant on the factory air pump. I'm telling you that stuff works ( DON'T LEAVE HOME WITHOUT IT ) , drove 60 mph all the way ( 1 hour from track ) & it was funny cause I still was passing some cars on the way home :LOL:.
Still had a good time & the place was packed !
WARNING - IF YOU THINK YOU HEAR A ROCK IN YOUR TIRE - CHECK IT , IT MIGHT BE SOMETHING ELSE ?
Thread Starter #2
Check out those R/T's o_O
Rcasa20
Indian Shores
2019 Redeye Widebody (sold)
@Mean Cat Which tire sealant did you use? Thx!
It was the tire sealant that comes with the factory air pump in the trunk.
tkracing1
Bay Area
2017 challenger
You guys are so lucky... no racing here. Lot's of rioting though.
Bboyd
Monongahla
2017 Hellcat
U are making us so proud!!!
Bboyd
Monongahla
2017 Hellcat
That does suck , hopefully your tracks will be open soon ?
LOL , Thank you sir ![/QUOTE
I need some lessons on those R/T....💪
Pretty simple , on the 3rd yellow ( on the tree ) let off brake & punch it , lol.
Bboyd
Monongahla
2017 Hellcat
Lmao I have to try that!!!!
