(Stuck) thermostat issue...?
Ronin
Muspelheim
'22 Challenger Hellcat
My '22 Hellcat is just under 3K miles and 2.5 years of ownership. I've noticed on more than one occasion, and most recently when I drove it the other day, the coolant temperature varying significantly. I typically drive it with the gauge dashboard on displaying oil temp, coolant temp, IAT and transmission temp. Daytime temps here are currently in the high 70s/low 80s.
My mods are in my signature and the only engine modification is an OCC, no tune, etc. I don't recall the exact temperature of the stock thermostat but thought it was 200 or something...? The temp sweep of the gauge is 170-260 and the 12 o'clock appears to correspond to 215 degrees.
The other day I was on the interstate for 10 minutes or so when it appeared to fluctuate rather wildly, and hit 2 o'clock hashmark/230 degrees momentarily before rapidly dropping to the 11 o'clock/200 degrees then back up to the 12 o'clock/215 degrees. Cruise on, constant speed, minimal load increase, etc.
I've noticed it do this before and found 220+ readings to be rather alarming, especially when I'm not doing anything remotely demanding. The rather wide and abrupt temperature fluctuations have me thinking it's a wonky thermostat, but was curious if anyone thinks it could be something else.
Both reservoir levels are where they were when I bought the car and there's no discernable loss of power, etc. Just the coolant gauge doing a jig while all the other gauges are reading nominally.
I know there's no benefit to swapping out to a lower temp opening thermostat without the benefit of tuning to adjust the fans. It gets crazy hot here in the summer, well into the 100-teens and seeing this happen the other day when it's relatively mild out was a little disconcerting...
Thanks in advance for thoughtful/helpful replies!
06SRT10NR
Knobnation
OEM s 203 deg
watched the digital gauges to see if the temps roam in the same range as the analog gauge?
any codes pop up in the IC? maybe P0218 [thermostat, coolant level/quality]? P010# [water pump temp sensor]? others?
heater working properly?
thermostat - $55-75, 20 mins to swap, been there, done that
temp sensor - forgot the cost, been there as well, had a local shop figure this one out and replace
heater core issues - $$ and pain in the ass to replace, clogged hose in/out of the core, not as expensive, but still a pita. dealer service dept extended warranty repair, so only cost me $100, plus many months of concern about all the dash/interior deconstruction needed to get to the fcker
Ronin
Ronin
Muspelheim
OEM s 203 deg
Thanks for your response, I appreciate it!
The digital temp gauge matches the sweep/response of the "analog" one; I remember that as soon as you asked.
I did NOT check the codes before posting, shame on me, but after checking there weren't any...
I swapped out the IAT gauge for the I/C coolant temp so the next time I'm out and about I'll see if it behaves similarly.
I'll likewise check the heater too, as unpalatable as that sounds! :ROFLMAO: Just like my home it never gets cold enough here for me to turn it on, but I'll manually do so on it's next highway speed trip. (y)
Forsyth
2023 Challenger Hellcat
OEM s 203 deg
This DOES seem to be an engineering failure.
Dash removal plus/minus steering column to change a heater core seems excessive, when other vehicles are accessed from front firewall or under dash. They got the cabin filter right.
Ronin
Ronin
Muspelheim
I didn't get to take it on the interstate for as long a ride as I wanted to but the coolant temp stayed around 12 o'clock/215 degrees and did vary downward a few times while the I/C coolant temp was dead stable at 80 degrees until I hammered on it and it jumped up to 92 degrees, which is 10/11 o'clock on the gauge...:unsure:
You should toggle over to the actual digital readout of the coolant temp to see exactly where it is opening up, that should happen at almost exactly 203, then ride out a dip to 195-197 before it's back up at 203 and opens again...eventually settling at around 200-205 while moving. Even in AZ you should not be spiking to 215 unless you are sitting in traffic, should hold at 203ish while moving. Your tstat may in fact be sticking, again try to watch for that initial opening up at 203 and that first temp drop. Good luck.
As far as running a 185 on the stock tune, I very much disagree that there is no benefit, the car still runs cooler and right around 200 a lot of the time, just not all the time. But with our summer heat and DA, anything that helps with that is good IMO. I will caution to say I don't trust most of the 185 tstats on the market as I have had a few go out in the last 2 years. I would only run a Mishimoto or Milodon, I have a Milodon now that I use in the summer season. Both the Mishimoto and Milodon will throw a code with the stock tune which isn't a big deal and doesn't affect anything about how the car runs, just have a light on in the dash.
Ronin
Ronin
Muspelheim
Thanks @EricG, I appreciate your response!
It has always run at 12 o'clock on the gauge dashboard which corresponds to 215 degrees, the fact that it jumped up as high as 230 had me shitting a chicken, especially considering it's relatively mild here and I was cruising at highway speed. Most definitely sounds like a stuck/sticking thermostat but I don't want a CEL either so I might just start with an OEM replacement and see what that does...
Ronin
Ronin
Muspelheim
Holy hell am I ever having a helluva time finding the right part number! I know that 203 degree is stock OEM but I get all sorts of conflicting information ("will not fit your vehicle", etc.) when I plug in my vehicle info and I'm not sure if that's because it's conflicting with the OEM temperature or if it's an actually fitment issue. I wish I knew the part number for the one Direct Connection is using for the Power Stage kits...
Occ?
OEM s 203 deg
Makes me sick when they go in deep like that. Very intrusive. 😞
Ronin
Ronin
Muspelheim
06SRT10NR
Knobnation
try this pn - 52028898AJ
Ronin
Ronin
Muspelheim
I ordered the Jet thermostat from Amazon:
https://www.amazon.com/dp/B001CHG19O
The Mopar/Direct Connection kits use a 180-degree thermostat (with tuning of course) so I figured I'd cut to the chase, since I will be tuning once my warranty is up.
Once I pull the thermostat I'll be curious to see if it's obviously defective. If it's not, it's clearly another issue, and I recall several folks having water pump issues. If that's the case I'll return it to stock and bring it to my local dealer for service. I did NOT buy the car from them after they fucked my over the pricing after doing a custom build order and deposit, and they haven't seen it yet...but I'm not gonna pay out of pocket for a warranty issue either.
Buyer beware on those Jet thermostats, I’ve had a couple go out on me, they either start to open really late or not at all. I had read of other people having issues too with them on other chats. I’ve had one become separated inside the thermostat housing too, luckily the piece did not drop down into the water jackets surrounding the engine!
I had used them for years on my previous Hemis, don’t know if there was a design or manufacturing change? But they initially open at around 188 which is warm enough to not throw a code on the stock tune, versus the Milodon or Mishimoto that open around 177-179. Yeah I too would like to know which unit comes with the Direct Connection packages.
Stock unit versus the Milodon, Mishimoto is similar to stock design but I don’t have a picture of it.
Ronin
Ronin
Muspelheim
Thank you for weighing in again on this, I appreciate it! I was driving myself batshit crazy trying to kind the part numbers for those thermostats AND if they're in stock. Do you have either one/both handy? I thought my Google-Fu was pretty decent but this is kicking my ass!
*ETA I believe the Mildon isn't even manufactured anymore, I checked the main website and there's nothing and looking for part number 16046 and it's OOS everywhere.
It looks like this could be the correct Mishitmoto:
https://www.amazon.com/Mishimoto-MM...=2022-40-286-3581--7-6-7-23333-23-1-1-5115---
If so I'll grab that and return the Jet...their quality has always been...average at best...?
Have you been able to verify if your thermostat is opening at 203 as it should? After the car is warmed up is run at a variety of conditions the coolant temperatures could go anywhere from 197/203 to up to like 217 when the low speed fan kicks on.
This time of year my car runs from 197 to 213 depending on street/highway and ripping on it, but it has been warm this week and I have hit 217 when the low speed fans turn on.
Stock thermostat is here:
https://www.eastcoastmoparts.com/oe...zcnQtaGVsbGNhdC1yZWRleWUmZT02LTJsLXY4LWdhcw==
Mishimoto:
https://highhorseperformance.com/mi...-thermostat-gasket-for-5-7-6-1-6-2-6-4l-hemi/
Milodon:
https://www.manciniracing.com/mihith1.html?gQT=2
https://www.jegs.com/i/Milodon/697/...ODT_XDdfksksQmfealWbZCuKsjpBjMlxoCajMQAvD_BwE
Good thing about the Jet 180 you ordered off of amazon is that it will come with an extra gasket. If you are keeping the car on the stock tune for a while longer I would just get another stock 203 unless you are comfortable running with a CEL light - I do it all summer like a bad ass outlaw! ;) I swap my thermostat every spring and fall, it's pretty easy when the motor is cold in the morning.
Ronin
Ronin
Muspelheim
Thread Starter #17
As I said in my OP the car was running with the coolant temp gauge consistently at 12 o'clock/213 degrees. It would occasionally dip below that but last week for no apparent reason it jumped up 230 which REALLY got my attention...
My research showed no shortage of folks who successfully used a 180 degree thermostat without tuning. I think the argument that the 180 is "bad" has little credibility with Dodge making it a standard replacement part in their pre-Stage Direct Connection kits.
I threw the Mishimoto thermostat is yesterday when I had a minute. I took it on a test drive on surface streets, state highway and interstate and it unequivocally made an enormous difference!
Nothing "looked" wrong with the stock thermostat, but you know how that goes. The ambient air here was in the mid-70s yesterday afternoon when I did this and it consistently ran just over 180, 183-185 when moving. The oil temp was also running markedly lower too.
Upon arriving home I let it idle for quite a while and it hit 204 very briefly then dropped to 199 and stayed there. I made sure to have the climate control off so the A/C wouldn't kick on.
My only regret is not doing this sooner. While tuning is necessary to adjust the fan speed(s) and take full advantage of the new/lower thermostat temperature, it is clearly not required for the swap to be effective.
My thanks to @06SRT10NR and @EricG for weighing in and providing helpful advice/guidance, I appreciate it!
