Power/ignition issues
AReece11
Columbia
SC
2022 Ram TRX & 2015 challenger hellcat
I have a 2015 challenger HC that is only used for drag racing and the car is already pretty well gutted. The last place to remove weight was the dash. So yesterday I removed the dash and steering column to remove the heater core, blower motor, and all the heavy sound deadening. Get it back together last night and go to turn ignition on and it flashes "service trans continue in D do not shift or turn engine off". And that wouldn't go off and was stuck "run" position but engine was not running. I ended up pulling the battery cable to get that to go off now when I push ignition button it dings once and that's it. Doesn't say no fob detected or anything like that. Also if I use the end of the fob, no difference. I disconnect battery for somewhere around 1-2 hours. New battery in the fob and I checked, it's showing 3.04V. I feel like I had this happen once before when I accidentally unplugged the proximity antenna. I have one in the trunk and one under the console, although I read there's supposed to 4 or 5? It started fine yesterday morning. Im lost..
Latest Forum Posts
