Any problems with FII Interchillers
WOHT
Lancaster
Dodge Challenger SRT
Has anyone had problems with their Forced Induction Interchiller Stage 1 and/or Stage 2 kits? Installation problems, temperature problems? I’d like to get some honest feedback. Thanks
@Hatermkr just installed one
Hatermkr
West bend
2016 helldemon
Did a stage 1 and 2 on different cars way better than a killer or a ic chiller better build everything fits better seals and connections can’t loose
W
WOHT
Lancaster
So, you’re saying that the FII interchiller kits are inferior to a Killer Chiller and Active Interchiller kits?
W
WOHT
Lancaster
Any issues yet? Do you consider this kit to be a “plug and play” kit, or is there actually work you have to do to install the system? Usually, plug and play means you simply plug it in, and it works, which doesn’t require additional equipment and effort. Plug and play seems like it you be effortless.
Hatermkr
West bend
2016 helldemon
You need to cut one hose. And add a relay. To me that’s plug and play. You get what you pay for. Your choice to buy what you want I know I installed all 3 and will only buy one
W
WOHT
Lancaster
I’ve done some extensive research with interchiller kits regarding installing, and I came to the conclusion that you need equipment to install any 3 of the major brands of interchillers; ac manifold gauge set, ac vacuum, ac reclaiming machine, O ring clip pliers, and so on. Not sure I would agree with you that it’s “plug and play”. What about cutting the high pressure side lower hose, and installing the 4 way fitting provided, which in many cases, requires the ac pressure switch to be extended by cutting the factory wires and relocating it down to the 4 way fitting? There is also the matter of drilling holes into your subframe to mount a FII interchiller systems, unless there’s some other way to mount it. It sounds like if you do not have mechanical skills and the proper and legal equipment already, you’ll have to spend quite a bit of money to buy all the equipment needed to successfully install it.
Hatermkr
West bend
2016 helldemon
That’s with any of the 3 kits.
W
WOHT
Lancaster
Which is why I disagreed you the term, “plug and play”. You have to invest in hundreds, if not more, of equipment to do an install on your own.
Hatermkr
West bend
2016 helldemon
Common sense tells someone you need to have it discharge and recharge
W
WOHT
Lancaster
Did you go with the stage 2 kit also?
W
WOHT
Lancaster
Yes, I agree with your statement. But, you would be surprised of how many people do not have common sense and just starting cutting lines. I’ve read many of them, unfortunately.
Depending on what you have going on, from what I know none are worth the money for me. They only work when you are not going down the track. If there is plenty of time in-between rounds then there is little benifit.
I am snot sorry 2 say,, butt, I devised dis system. Been a chiller tech fer 40 ears and came upster wit da system 2 run off da 134A refrigerant frum da factory. Remembuurr da 1st 1ns came out wit da box of ice. Den da next waz a whole different system, no guud. Tat is why I devized da 1- 2 wurk off original system. Dare is no such of plug and play system. Not. I have contacted da idiots dat say da same ass to cut and turn on. No. Wood youz dew dat 2 your a/c system at home. No. Cut and whack and watch gas spuw out and figure dat will wurk?? Hell no, buttster youz don'thalf 2 spend a huge amount of $$ 2 install. Yes, youz doo need extra gas, guages, fittens, tubes, tape, cummon cents, buttster snot alot. If youz waz 2 purrchase da stuff at, say Auto Snow whore da like, tell em whatz youz bee doin. Day wood lend you da guages, sell da gas,, butt snot da canaster, sell fittens and da like, cheap. Dew snot use old used tuben. Humidity gets 2 it will bee contaminated. You have 2 purge da system 2 relieve da humidity whore else?? Dis plug & play is watt it saz, play. Cummon cents is coreect. Bull shitster. Dew it correcdum and it will wurk. Like wa, cheap skatester. Deevize a HX system dat draws da heat out of da system by culant whore air. Da plug & puke is ha guud sellen point butt? Right. I went 2 da local hot rod shop, privatly owned, and wa and da mechanic priced upster a system dat wood wurk. Utter dan da plug & finkster and da price waz ovah $18,000 wit me duen 1/2 da labah. No f-ing way. Eye con add 2 moe HX, inner coolers, fer 1/3 da price wit extra ruum.Cum on. $$$ all about.
