Sign Up! To view all forums and unlock additional cool features
Just asking if swapping a stock pulley on my Redeye for a 3.17 pulley would require a tune? Or is a tune necessary to get the full benefit from the added boost?
Some say that you can do it without a tune. I had a lower pulley put on mine and it ran horrible which is supposed to be the same. I don't know for sure.
My friend has a hellcat and he put on a 3.17 pulley without a tune, has a nice dyno graph but trapped at 120mph to my 126. My charger is all stock, ran a 10.9 in the heat he was 11.3- 11.5 range
Hmm well I guess you didn't know that when E85 when knocks it is a lot more harmless than race fuel or pump gas
Also the e85 I run is 112 octane and not the 105 octane from the pump. I can run the same timing table on both but I just feel safer running the 112 especially when racing. On a tune I've spent 100 hours of research on.
I know exactly what is going on with the tune in my car I also know exactly what to look for in a log to know if there is an issue. Changing things based on weather.
Can you say the same? Do you log your car?
I have a tuner who looks at my data and makes adjustments as needed.
I looked at E85 but it's hard to get around here and it would go bad, in a drum, before I used it all. This from my race fuel guy.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
