2021 Durango R/T battery warning light
There's a recall on them?? I'll have to get mine done. Headlight turn signal went out requirement replacement if the entire headlight, service uconnect box message, and blown rear load leveling shocks
Damn, what on a 2021 R/T?
So far the Durangos have been okay, but we've learned to keep a close eye on the voltage in the '21 TRXs.
No idea what caused it, one day the voltage on mine started out low, maybe 12.8 or so after starting it, then just kept dropping. Was down to 12.2 at one point and that was after noticing that it'd charge on deceleration. And only during deceleration.
Mine seems to have self healed and is happily showing about 14.8 after starting, then going down to 14.2, just like it should be. My girlfriend's isn't as bad, but she came home with 12.6 volts showing the other day, which is too low.
I still haven't figured out what's going on with them.
Not to worry, that's mostly alligator induced damage. You should be fine.
Agreed...and then again...who can tell what get's damaged when he starts swinging that sledge hammer around..:unsure::unsure::unsure:;)
