IC Chiller install & review
I know, it’s definitely not the norm. Not user error either. It’s possible they provided the incorrect pipe to an fittings but I doubt that
Some people think JIC and AN are interchangeable...
If IC chiller included JIC you can tell. The taper on the male fitting would be a different angle.
Thread Starter #363
To clarify, these are NOT fittings that were included in the kit or provided. These were self purchased directly from Vibrant for coolant lines only. I used the AN fittings instead of plastic ones.
Detroitboy
Law Enforcement
Macomb
2021 Charger Redeye
My fittings leaked, as did others I bought. I finally called them and they told me they had some bad ones and switched suppliers for the correct ones. They sent me new ones and they did not leak a drop.
Thread Starter #365
From where, vibrant?
2022 Charger RE WB
I made a video detailing my installation, as I said I would. I am not a YouTuber, and I never do that. But, perhaps, it will help someone out. I think it is worth a watch. I have a lot of time into the installation. Enjoy.
Katy
2018 Trackhawk
Very nice! Watched it start to finish. Love the attention to detail. I was going to use oem style constant tension band clamps but will look into getting those oetiker clamps, looks cleaner.
Also love the way you have it plumbed (chiller OR stock exchanger) to take the load off the chiller in stock exchanger mode (I'm in Texas).
Just a question, but besides the cleaner look, any other reason for not using the foam insulation on the hoses?
Once your up and running, I'd love to hear if the braid on the hose reduces/prevents condensation from dripping.
2022 Charger RE WB
I did not see a real need for the foam and did not want to deal with it later when it deteriorates and starts crumbling off. What a mess.
Having said that, I have not noticed any condensation on the thick fuel rated rubber hose I used from Improved Racing. Likewise, the braided line is dry. I get condensation on the metal fittings and the stock hardline pipes.
2022 Charger RE WB
As some of you know, I have a 2022 Charger WB RE, which came with the factory chiller. One thing that is also missing from the IC Chiller installation notes is exactly how much to charge the AC. The stock charge is 1.5 lbs or 32 oz. I started my setup by charging to 1.7 lbs or 27.2 oz. The instructions talk about adding 1 oz at a time and checking temps. I have been messing with this. I added 1 oz, and it got slightly cooler. I added another 4 oz (to make it 2 lbs total). I saw maybe zero improvement, but it was not worse. Who knows what it should be?
Couldn't they have calculated the volume one the stock unit and then what volume their unit added to figure this out? I wish I had known or thought about. I would have at least filled each unit with water and then poured it out to see the volume difference. Now, I am shooting in the dark. I have seen some other posts talking about starting at 28 oz or where FI Chillers take 3 lbs.
Any data here would be appreciated. Or, maybe I will just have to keep messing with it. BTW, I am using a professional shop system/tool by friend has at his shop. So, no air or contamination is being introduced. I wish I also knew the total volume of the lines and other pieces of the system. That might help figure out how much volume was added by the IC Chiller.
Katy
2018 Trackhawk
Not sure how much this helps Charger/Chally's, but I just finished up my Trackhawk. Published oem R-1234 fill 20 oz. Shop said they only recovered 17.5 oz (and 0.2 oz oil). IC gave me instructions to have them put under vacuum for 1 hour and refill to 29 oz. I added 1 oz oil to the new chiller just in case. It is working like a boss. In cabin/chiller mode, cabin blows 42 deg and chiller gets to 50 deg (90 degrees outside). Haven't played with the drag valve too much as I don't feel like sweating right now. But it did reach the 30's on a brief test.
The lines are different, but think we share the same IC core? So that should give you at least 1 data point. Also, I printed out the service manual a/c performance spec for the Grand Cherokee which gives a chart providing the max allowed cabin vent temp vs apparent ambient air temp then shows the expected suction and discharge pressures. With the charge value IC provided I logged the discharge pressure with HPT on a drive and it was also right in the sweet spot. Worse case, you could check if your charged properly based on your vent temps, suction and discharge pressures and reference the service manual?
2022 Charger RE WB
You say the shop recovered 17.5. What does the sticker under the hood call for when it comes to the stock charge? 17.5 had to be low.
Thread Starter #372
Pull a vacuum to fully drain and condense the oil in the compressor. If you cracked the lines open you messed up. 28, and check temp coming out of vent and chiller efficiency. Shouldn’t need any extra oil if you’re actually using a machine.
Katy
2018 Trackhawk
Sticker said 1.25 lbs. Never felt that it was under-performing though. Low miles (12k) so maybe under charged from factory or the shop machine was off. Was there with them and saw the display.
Correct, shop said they could replenish the oil recovered with their machine. They suggested the extra ounce, either added manually or by their machine, since the core and lines are new. Similar to service manual procedures when replacing condenser or evap, to add a small amount of oil to the new component. Was trying to lean on the safe side I guess.
