- Member ID
- #1258
- Messages
- 54
- Reactions
- 73
- Likes
- 17
- City
- Austin
- State
- TX
- Country
- United States
- Vehicle
- 2017 Charger Hellcat
I've found a lot of the internal courtesy LED lights in the Charger were colored similar to 2700K White (Daylight, in bulb standards) in order to match the original incandescent bulbs. As I went around the car changing out incandescent bulbs to 6K White LEDs, I now have a mix of daylight white and cool white illumination... many of the 2700K LEDs are not easily replaceable bulbs, but rather soldered to little circuit boards here and there.
I'm thinking about making some circuits to replace the ones in areas like the front overhead center console (3 LEDs there need replacing, these are the most annoying and visible), and maybe the wiring harnesses in the door panels that illuminate the door pockets (all four door panels appear to use the same LED harnesses). Where else should I be looking for these offenders?
Does anyone know of Charger LED bulb kits that go to this level of change - most that I see only swap out the easily replaceable bulbs which I've already done.
Thanks!
Thanks!
