2015 Hellcat brake pad shifting
Finally identified the metallic knock in the left front right side of the Hellcat. Apparently the brake pad is shifting forward and aft in the caliper. Anyone seen this one before. Also any idea on a fix?
Not an expert on this Greg;
pad is ok as is?
Pins in calipers ok?
pad is ok as is?
Yep everything is good. I’ve been using Power stop pads on both cars since I got the Hellcat in 2015. First time for this problem.
Don't these have backing plates held in place by little metal 'tabs' that bend around the pad frame? If so, could be broken or loose tab(s) on that pad ?
Yes they do and they look good.
Thx
