Proper orientation when checking engine oil level
I insert dipstick with hash marks facing towards front of car/me. Otherwise you get 2 different readings from the front of stick vs back.
Front of hash marks
Back of hash Mark's
What do you all do?
Murfreesboro
2016 Hellcat Go Man Go
Mine has the new style "blade" dip stick and I actually like the cable version like you have better.
I put the has marks inboard toward the engine. You can't really orient the blade style front/back.
2fast4u
Edwardsburg
Never really payed attention to orientation, is there a significant difference or just like a diamond's diff? I always use the same side I see when pulling it...
I believe so, front side facing you seems to show higher level vs back side. Always assumed you check side facing you thus put dipstick cable with hash marks forward. Just curious.
Catless
Parkersburg
WV
2015 Hellcat Challenger
Either way you look at it, it is within spec.
I believe strongly in proper orientation when checking my oil. I always try to be standing while doing it. When lying on the motor, or worse, on the ground, it significantly adds to the difficulty of the reading and is usually inaccurate to boot.
Take it to the dealer.
Good one.
I have never heard/read a definitive answer from SRT on this. The book says 7 qts but it NEVER read correctly on the stick. (I have early model 6.1 with blade dipstick). I wasn't 100% sure if you should go to what the STICK read or the BOOK (again with no def answer from the authority). I then did a fresh oil change with filter and did the full 7qt change. Drove car and let sit awhile. Whatever it read (was over) I marked with a score on the stick. That way regardless I know exactly where the true full 7 qt. mark is.
I have been told my could take be measured at 7 but that was in mm. Never a disappointed dick stick interview entrance front or back. Sticks get stuck at times and start over.
Hey 7mm or 7 inch all feels the same for you. Maybe not so much for the other person .LOL
And then to make it even more fun they swapped out OEM dipsticks WO changing the text...
Jungle Cat
Dracut
MA
Take a reading after an oil change probably better the next morning after the first drive. Check it both ways then you will know where it should be full.
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
I hated the bullet style dipstick. yeah it is a little easier to put in. But if that is a problem for anyone they shouldn't be doing it anyway. They are hard to read. FCA with their oil change requirements. the oil is not dirty enough to see it .Easier to see the sheen in the light on the blade style.
Don't let the orientation bother you. No matter which way it swings, it still does the job you pay it to do ;)
are we still takin bout oil?...cause my nipples are getting hard
I’d think gender fluid would be the proper orientation here.
hey...I don't judge how oriented the fluid is...just as long as it does what I need it to do
Usmc341
Henderson
NV
I put in 6 then check the level. I fill it slowly until it's between the hashmarks. I've never been able to put all 7 in due to residual. Better to slightly underfill than overfill.
