P0304 error code - fixed but still issue
Belgrade
MT
2022 Challenger RE
Car has been throwing this code - dealer cleared it a few times, but after coming back on for a 3rd time did some more checking and did a repair per the following.
Per repair invoice from dealer:
concern: indicator/warning lights concern (check engine light is back on advise)
cause: dtc p0304 during inspection found cylinder 4 misfire was caused by a injector threat was not closing, spark plugs fouled
correction: installed new fuel injector into cylinder 4, amd plugs for cylinder 4
Well, during test drive at dealer once fixed, light came on again. Dealer checked connections, was hoping there was just a loose connection.
Got car back, drove car next day all good. Next day, same check engine light came on. p0304 so car is back at the dealer.
So far they have tested the coil and the coil is good. Maybe they said they moved the coil to other cylinders and light still on. I'm no mechanic, but something like this was the recent update.
Thoughts?
Thoughts?
ROYAL PITA if you ask me...hope the service dept. is a good one
Be a hard ass until it is perfect! Maybe ask around for a good dealership in your area. Mine has 1 good tech, I ask for him to do everything.
When he quits I hope goes to an local shop so I can bring them my car.
B
bobn
Belgrade
MT
2022 Challenger RE
I live in MT so only have one local dealership. They are talking with Dodge.
Is this a warranty deal?
Also did they replace 1 injector or all 8?
I hope...it's in English...:rolleyes:
B
bobn
Belgrade
MT
2022 Challenger RE
yes, they replaced only injector four. And yes, it’s a warranty issue thank goodness.
Dealer has had the car for 7 days now. Still not fixed.
Dealer has been communicating with “star,” which is the system Dodge uses for communication with corporate and the dealer. And have been doing some testing per stars direction. .
i’m kind of surprised things are taking this long.
No way I’d let them just replace the one. Injectors come in a set for a reason.
B
bobn
Belgrade
MT
2022 Challenger RE
I am no mechanic so you may as well be talking in Chinese. ha
What does that mean they come in a set? What should I be asking the dealer?
