ACTIVE INTERCHILLER
Trader history for TrekGTO (0)
ST PETERSBURG
05 Maggie GTO
Active Interchiller is the original Chiller that developed Competition Mode and Automatic HX Bypass in 2009. We have the only Progressive Refrigerant Distribution Device in every core and CNC Refrigerant Adapters for a no AC hose cut installation.
2006+ Charger 2008+ Challenger
We supply modified New OEM Liquid Line, Competition Valve, wiring harness, relay, 10' insulated hose, switch and LED for the only true Plug N Play Hellcat Interchiller Kits. Our Programmable Automatic HX Bypass upgrade is compatible with any pump and allows you to retain your HX. We provide you a measured amount specification for R-1234yf that is less than 2lb system total due to our 2 fitted refrigerant hose no-cut design.
Pictured With HX Bypass
19" Competition Xtreme Chiller
No HX bypass $1299
Automatic Digital HX
Bypass Upgrade $150
Stage 2 Upgrade $549
TrekGTO
ST PETERSBURG
05 Maggie GTO
Thread Starter #2
Thanks to Richard in TX for buying our 19” Competition Xtreme Chiller -12 with High Volume HX Bypass for his 4.5 Whipple Hellcat and for the hook up with our newest Installing Dealer R2 Motorsports in San Antonio. Contact Leroy at R2 Motorsports for all the popular model Active Interchiller installations.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Charles in TX is installing our 19” Competition Xtreme Chiller ¾” with High Volume HX Bypass at home on his 2017 Hellcat 4.5 Whipple,
TrekGTO
ST PETERSBURG
05 Maggie GTO
Hellcat & Trackhawk 19” Competition Xtreme Chiller in Stock and Shipping. 100% bolt-on no cut 13” Super Chiller also in stock. 20191102_115949.jpg
72 440 Barracuda
Graham
Hellcat & Trackhawk 19” Competition Xtreme Chiller in Stock and Shipping. 100% bolt-on View attachment 5773 no cut 13” Super Chiller also in stock.
I have been seeing these interchillers and I am curious if that creates a warranty issue- just cooling the intake charge right? But I would expect it would be a reason for Dodge to void the warranty anyway...
TrekGTO
ST PETERSBURG
05 Maggie GTO
Probably void the AC warranty
TrekGTO
ST PETERSBURG
05 Maggie GTO
Steve in TX Forged 392 TA 2.9 Whipple. Competition Xtreme Chiller 1" Hose and High Volume HX Bypass.
Magnolia
2018 t/a
Recieved my Interchiller system from dave
Awesome kit
TrekGTO
ST PETERSBURG
05 Maggie GTO
Our Installing Dealer R2 Motorsports in San Antonio, just did a Hellcat Interchiller install with a custom bumper reservoir with a bleed line we recommended to T into the factory underhood reservoir to bleed trapped air out. Tech promised pictures to document the install.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Installing Dealer R2 Motorsports in San Antonio, Custom Reservoir with our Automatic HX Bypass
TrekGTO
ST PETERSBURG
05 Maggie GTO
C7 19” Competition Xtreme Chiller with our automatic HX Bypass for Max Performance Engineering Mesa AZ. Loren is an Installing Dealer, hit them up for your build. This one is for a 1000+ HP LT4 that likes to compete in 1/2 mile events in AZ, can't think of a better use for our Interchiller. Our C7 kits are 100% bolt-on and complete, no refrigerant hoses cut. MAX Per.jpg
TrekGTO
ST PETERSBURG
05 Maggie GTO
C7 Competition Xtreme Chiller -12 for Tim King Performance. Contact Installing Dealer Tim in Dayton OH for your next build. They ordered this No HX Bypass 100% bolt-on nothing cut, complete kit for a customer LT4 build.
TrekGTO
ST PETERSBURG
05 Maggie GTO
Trackhawk 19” Competition Xtreme Chiller -12 with Digital High Volume HX Bypass for Justin in CA. 100% bolt-on nothing cut, complete kit.
You have a kit for 16 M6 Challenger Hellcat? With heat exchanger bypass
TrekGTO
ST PETERSBURG
05 Maggie GTO
Email sent, THANK YOU
TrekGTO
ST PETERSBURG
05 Maggie GTO
TrekGTO
ST PETERSBURG
05 Maggie GTO
From ncrowe...
"Best $$$ I’ve spent so far - no ice needed - no additional fluids - just using AC.
Broke my ballsack - lol, The reason for the increase in MPH is from the Active Interchiller I installed - my IC temps are 55 degrees at the line and my IATs are usually ambient or just above - at the end of the quarter my IATs are just touching 100 degrees and my IC temps are usually right around 80 degrees - they used to be MUCH higher."
TrekGTO
ST PETERSBURG
05 Maggie GTO
Thread Starter #19
Trackhawk 19” Competition Xtreme Chiller -12 no HX Bypass for Larry in NY. 100% bolt-on nothing cut, complete Interchiller kit.
TrekGTO
ST PETERSBURG
05 Maggie GTO
