DSS 9” conversion-SOLD
Trader history for Tuckerracing (2)
Tuckerracing
Whitehouse
Used DSS 9” for a hellcat style rear cradle. Has 33 spline wavetrac LSD, street-strip gear set with brand new 3:00 ring and pinion. I am going to a solid axle setup and do not need this now. $5,000.00 plus shipping, it is currently on a pallet ready to ship.
Does not include a driveshaft, if you have an aluminum one piece drive shaft, any reputable driveshaft shop cut yours down and install a 1350 u-joint setup for the rear.
The 3.00 ratio is what you will want to run if you are using the factory A8 transmission. I will include a 4:11 ring and pinion that you can swapped on the 3rd member if you are using a TH-400 or Powerglide.
GLWS
Trackhawk, RS3, Golf R
No driveshaft?
411s????
Tuckerracing
Tuckerracing
Whitehouse
no driveshaft, i am using it with the solid axle set-up since it has a yoke for a TH-400.
Tuckerracing
Tuckerracing
Whitehouse
Yes it is 4:11’s, with the TH-400 I have that is the gear set Rossler wanted me to run.
Tuckerracing
Tuckerracing
Whitehouse
Update on this set-up. I am having a set of new from Quick Performance 3:00 ring and pinion swapped with the 4:11 ring and pinion so this set-up will be ready to use with factory 8-speeed transmission. I will include the 4:11 ring and pinion also if someone wanted them. So complete set-up with a brand new 3:00 ring and pinion and extra 4:11 ring and pinion for $5,000.00 i can ship or if you are in Texas I can meet up for delivery.
Edit your original description to match this.
Wonder if this would work in a Trackhawk? Guessing no. Anyone?
Now it’s looking like a decent buy, shame no driveshaft
Dman007
6 Second Best E/T
Smyrna
2019 Charger Hellcat
wow That's a great deal!
Tuckerracing
Tuckerracing
Whitehouse
Trackhawk has a different style rear diff.
Tuckerracing
Tuckerracing
Whitehouse
I can deliver to the DFW area and Houston also and will be driving out to MATS in Las Vegas for that event can put it in trailer if someone wanted to meet to purchase it.
Tuckerracing
Tuckerracing
Whitehouse
SPF
Tuckerracing
Tuckerracing
Whitehouse
