IC Chiller install & review
I received in today a spare Mopar AC compressor, look at pressures listed on the tag. That’s some high pressures!!
Thread Starter #123
Thread Starter #124
Thread Starter #125
Thread Starter #126
Jumped the gun and started ripping car apart before I had it evacuated. So it’s all installed and plumbed coolant wise, and now that 3 way salve is wired up should be fine to drive to shop. Also a good test to make sure nothing in the water side leaks. Hoping for AC lines to go smoothly
Un Holy One, do smot qui your day job. I waz toldby Lambo Rico dat I waz mot on hea anuff. I think I am on hea just enough. Da Lambo 1 is snot hea enuff.
Thats only a manual thing, brake pull release lever. @Unholy707 car started life as a manual. Autos got the foot pedal.
Thread Starter #131
What hose did you use on that Maddox coolant refill tool? Never put a hose on that end for evacuation.
Real stretchy 3/4 gates hose just taped, didn’t need to though, it didn’t spit out any fluid. That vent unscrews and you can screw in a fitting for a hose - might do that one day
Dang man, run the vacuum while you're in there my OCD is triggered :LOL:
Thread Starter #133
No way, car is all go no show
catdad
Lake City
2019 Charger Hellcat
Thread Starter #135
Done!!!
Thread Starter #136
Ac lines are very straight forward and easy to do, took a few hours screwing around. Make sure you index everything with a marker, take it off, and then tighten the cnc fittings to the screw on hoses - makes life easier, and less chance of it coming loose. I used some left over pag oil to lubricator washers and o rings. The biggest feat is the plumbing for the 3 way valve. It’s a pain, but I can confirm it does keep the IATs and car just as cool as if it wasn’t inline when flowing through the heat exchanger. Big test is when I get it recharged 🤞🤞🤞🥶🥶
Thread Starter #137
Also not a bad idea to mark your hose, cut, and crimp outside of the car - very easy to route the AC lines fully assembled
Thread Starter #138
If you have a switch go bad let me know I bought a 10pk of different colors off amazon. I had 1 go bad on me 3 months into using it.
Thanks man! Will do! I actually want to get custom billet switches but my cars not nice enough for that, heck it has a plywood rear seat delete 😅🤣
Thread Starter #139
Very nice kit @uncrnps !!! Can’t wait to see what it does
Thread Starter #140
I’m more worried about all the coolant lines than all the AC lines (no leaks!) if a hose go bad, besides having it evacuated, it’s small potato’s to change them out. I feel like I could plumb this all up again in a day, hours if not using the bypass. A lot of time was spent trying to figure out all the plumbing
