Big OOF
Yeah, and the difference is?
I've had my dog 3 times longer than the cat.
Why you inglorious unsensitive Bastard you...;)
I'd shoot somebody for hurting either
Sorry to hear that it made a peekaboo window, however it will make a nice table now. Look forward to seeing more from you once you get back up and running.
(y)(y)...Hmmm..I just might change my mind about you...:unsure:
I didn't realize that he windowed the block?!?!
3rd image of first post, back in the shadows...
Redeye cam is 5150 gun drilled tool steel, Hellcat cam is a solid ground forging, about a lb difference between the 2
just think that could have been you but you backed out:unsure:
white1
white1
Prairieville
LA
2020 hellcat charger widebody
Thread Starter #32
I’ll be going with a custom cam is the plan.
Btw your drain plug is amazing. I’m not sure what was stuck to it, but it was hard to remove hahaha.
On another note I checked the dipstick Wednesday to see if there was any glitter in the oil and it had zero on the dipstick.
gave me some false hope but appears it attracted most of not everything to it
white1
white1
Prairieville
LA
Thread Starter #33
He lost a motor....not the family pet...
Exactly. I can build back stronger. Mess with my pups and we got issues
white1
white1
Prairieville
LA
Thread Starter #34
Stronger bottom end, more cam, may as well add some boost and more nitrous 🤷‍♂️
maybe for next tx2k I can have a 8sec banner by my name
Now girls. If I can make it from 1981 to the el present, being a vegetarian, not living in Nancy land, bitch, you gals can live off 93.. Going into my shine mode,, gets better. I did 2 use the dip stick, # 3, she locked me out. But the magnetic stick worked great. Depends how you look at it.
I can tell you witch one I would cry over losing & I don't own a pet. :LOL:
TX2K22 was a great time.
I knew to test and tune from A to B
to ONLY use the nitrous if needed in eliminations.
Well, I got confused on the car beside me and knew it would be a good run on the spray during test and tune so I sent it!
Heard it break up about 1000' but by the time I could get off the nitrous was a little too late.
Got a "smoke warning"
drove the car on the trailer, started it back where we were parked, and drove it off the trailer into the shop.
Wasn't sure what I'd find. Was HOPING for a head gasket but never heard of a stock engine hellcat blowing a head gasket. Figured it was a piston. Started looking this morning........
I did some research over the past couple of days and read that at a certain power level, the small end of the connecting rod will let loose at the wrist pin. I figured I had a ways to go before I got to that power level. Guess not.
Also, the required engine diaper did exactly as it was supposed to. I had zero idea to the extent of the damage as other than the smoke out of the tailpipe there was no oil anywhere. It sat on the trailer from wednesday until yesterday with no oil other than from the tailpipe. I parked it at the lift yesterday, and this morning when I picked it up saw a small puddle of oil. When I started to drop the diaper, it was full
Enjoy my suffering hahahaha
Now to decide what to do. I do have a spare BGE bare block so now my mind is all over the place
Sorry that happen to ya @white1, hope you get it going soon.
I didn't make it either but a buddies Demon ran 9.40 stock boost, E85.
I wood shoot any one that would attempt to take my guns and or kat not in that order. Kat weighs 22 lbs. He can take care of me.
Which piston was it? Plug in the picture looks fine so just sounds like another unfortunate mishap on a stock Hellcat rod.
Latest Forum Posts
