Should I gamble with this one?
Derry
2015 Challenger
Looking at a 2015 SRT 392 6 spd. I took it for a test drive and it runs and drives great. It’s really clean too. I just can’t get over the mileage 125k. They want $19k. Car fax has consistent history until 85k. It changed hands a couple of times in the last 15k miles. Looks like it was between dealers. I know I could spend a little more and get something with lower miles, but I have 4 cars in the driveway right now so I don’t want to spend a fortune on another one. I just miss having some thing with a V8 and a stick. View attachment IMG_4454.jpeg
06SRT10NR
Knobnation
with that mileage, I'd think 15-16k would be more reasonable. but first, need to know if it really in a 392, do all the VIN's match, and why the hood and spoiler were replaced with more recent versions. taking advantage of damage to change the appearance? some other issue? just wanted to change the look? were other parts swapped? the after market fender flares and wheels are a nice touch, though.
C
Derry
2015 Challenger
It was in a minor accident and they decided to change the hood since there was some paint work being done.
Looking at a 2015 SRT 392 6 spd. I took it for a test drive and it runs and drives great. It’s really clean too. I just can’t get over the mileage 125k. They want $19k. Car fax has consistent history until 85k. It changed hands a couple of times in the last 15k miles. Looks like it was between dealers. I know I could spend a little more and get something with lower miles, but I have 4 cars in the driveway right now so I don’t want to spend a fortune on another one. I just miss having some thing with a V8 and a stick. View attachment 174309
Man...that's a ton of miles...I'd pass..but that's just me...
Define minor..
C
Derry
2015 Challenger
I don’t have much info or pictures. Who ever did the repair did a great job. It’s spotless, but the mileage is tough. Even searching online it’s almost impossible to find any over 100k. So I know once I buy it I’m stuck with it until it dies since it won’t have much value down the road.
Then only buy it if you plan on keepin it for a REAL long time...
It’s got the fender flairs. Don’t many of those.
Fit on that hood & the RF fender are definitely 'off', guessing that's from the accident repair. LF looks askue as well but hard to tell in that pic.
At the very minimum I'd have a known good collision shop give it the once over + a solid mechanical inspection.
Price seems high to me given the age, miles (on a northern car), accident history and missing history for the last 40k miles !!
If it's being swapped around from dealer to dealer that means others have passed on it for quite some time & price should be low, low, low.
22RENBS2 & 170
I'm not far from Derry, I can take a look tomorrow if you like, never hurts to get a second set of eyes on it.
I know nothing about 2015-2018, but I can spot repairs and funny things. The guys here can help you a lot.
The 392's seem highly desirable because it is the lower cost alternative to the HC, and the lower the price, the bigger the market. It sounds like this is a basement level car, whether or not it is a bargain is the gamble. Multiple ownership changes is never a good thing.
I would hope the 392 is good for 200kmi, the trans is hopefully good for that too, I expect a clutch might be needed.
If you are looking long term, and the car is basically straight and sound, then this might be good car for you. I would have a Dodge dealer inspect it, paying close attention to the engine, trans and suspension. It will likely need repairs/maintenance, lot of things are near the end of their life, but if you are willing to accept the cost and build it back into a great driver (given the caveats above), it might ok, it might be great, it's a gamble.
PM me if you would like me to go for a look.
rayzazoo
Hellcat
The only issues I’ve seen with the 392 over the years is rocker arms failing, and that’s only if overrevved beyond 6100rpm. It’s a good engine, especially if you don’t have the 8-4 cylinder deactivation (e.g., manual transmissions)
With that mileage, the following comes to mind:
-clutch
-spark plugs
-coolant flush
-rear differential
-brakes (rotors, pads, fluid)
-rear axle boots for leaks if lowered before
-driveshaft center carrier bearing
-tires, wheel balance
-alignment
Only issues I’ve seen with the 392 over the years is rocker arms failing and that’s only if overrevved beyond 6100rpm. For the most part, it’s a good engine especially if you don’t have the 8-4 cylinder deactivation (e.g. manual transmissions)
Wth that mileage the following come to mind:
-clutch
-spark plugs
-coolant flush
-rear differential
-alignment
Thats alot...
C
Derry
2015 Challenger
2ndAmend, I sent you a message.
C
Derry
2015 Challenger
MikeD1, that seems to be the going rate around here. Maybe slightly on the high side. I’m not bothered by body work, I plan on driving it here and there and keeping it down a while.
B5Cat16
S
It's your money so it's your choice but I wouldn't entertain the purchase. Too many miles for my liking. $17k tops if you decide to do it.
If it's been maintained well,,and hasn't been beat on...and your plan is..to make it an occasional driver you should be good to 200...(hopefully)...@ which point it will be virtually worthless..but yer not concerned about re-sale...you sound like you have convinced yerself to buy it...break out the check book
The mileage is just too high. You are mistaking if you don’t believe it’s going to be a money pit. I don’t know about the trans and drivetrain but it’s the lifters you have to be worried about. If a needle bearing goes bad in a roller lifter, you can wipe the cam and basically the motor is toast. A lifter went out in mine at 144,000 miles. I caught it in time but it was an expensive fix. ECL just indicated a miss in #5 cyl but you couldn’t feel a miss.
I would have to agree with you...my guess he already bought it
22RENBS2 & 170
He emailed me and said he took a 2nd look at it. He was worried about the clicking and included a video. I told him they all click, it sounded loud in the vid but it's hard to tell, not sure how close his phone was to the valve cover. I suggested taking it to a dealer or to a local specialty shop that I used in the past. He never took me up on my offer to go look. Waiting for an update...
my guess he bought it...
