Need help deciding what to wire kill switch to…
Kill switch installed and now I’m just looking for suggestions as to what wire I want to interrupt and where to find it. Car is an M6 so going to the starter solenoid while good, would still permit bump starting the car, I would have to think. I also don’t want to completely cut power to things that require constant juice, like the computers, etc. Suggestions please, and thank you.
Remember an old simple one? We are both “old”:love:
Primary ignition wherever they hide that.
Hope there is not eight of them!
On this car who the hell knows?
Idoru99
Springfield
2021 Challenger Redeye WB
fuel pump power supply?
Thanks. Sounds like it might work for sure. Any idea where I can find it? I don’t have a wiring schematic. I guess I’m looking for someone who’s already done one with an M6.
Open the hood. Look to the left. Your box is more than likely black. Mine is red, been painted. See a small plastic cover, open it up. Sea the wires,?? Cut em all. If it sparks, you got the right ones.
GBLWRMR
South
2022 Super Stock
I don't have the wire color but I believe that it is located above the passenger kick panel and also under the back seat. Let me see what I can find and I'll post back
@GBLWRMR Great. Thank you.
GBLWRMR
South
2022 Super Stock
The wire location I was thinking about is STARTER kill switch and located on the passenger side. I privately sent you a link to where I read about it. On the other hand- the fuel pump control module is in the trunk, right rear under the liner.
Nope, passenger side box. Back end is battery pos neg terminals. Red one dev give away. Mine is constantly hooked up to a trickle charger. Or tickle charmer from Diamond Dolls.
@GBLWRMR Got it, thank you.
Still looking to wire a kill switch on an M6 car. Starter relay ng as it can still be push started. Looking at the blue/orange fuel relay wiring and looking to splice my switch into that. I already have the rear seat delete so lifting the lower part done. Now I see two blue/orange wires going into the d/s fuel pump. Any idea if it matters which one I interrupt with the switch?
