My 9 second daily driven setup.......
FFBOS
Mount Prospect
2016 Hellcat Charger
This "list" below is from my phone/laptop. I always keep a running list of what I've done or experienced with the car.....I'm not OCD, but organized :) They are my personal notes, and a great "pass along" if I ever decide to sell the car, which I have no plans on doing.
  • Supercharger replaced under warranty 3,000 miles. Bad bearings. Replaced with "AG" unit.
  • Right rear shock replaced 9000 miles.
  • Front rotors replaced at 5500 miles.
  • E85 at 9200 miles
  • Diff fluid changed at 12,450 miles (Amsoil 90w-120 with slip lock)
  • Trunk lid rust area (fixed personally). Filed with FCA.
  • Front bumper backed into at a gas station 3/27/18. No dents, but chipped paint. Re-painted portion. Re-wrap not to perfection.
  • 3/1/19 noticed rattling from snout. Probably "play" in bushings from fixed metco pulley.
General:
  • 2016 (May 2016 build) purchased private sale for $60,000 on 2/17/17. 1900 miles. Delivery 3/9/17.
  • B5 Blue
  • Red belts
  • Harmon Kardon
  • 2017 PK HR5 rims with 275 555 G2’s in front and 315 NTO5R DR’s in the rear.
  • 2016 factory rims with blizzaks for winter.
  • Forgestar D5 Beadlocks 17x10 305/45/17 ET Streets for racing.
  • Block heater (hotter than factory) installed for ease of e70/e85 starting in cold weather.
Interior:
  • All Led interior
  • 2017+ RED SRT Airbag
  • 2018 DEMON u-connect with 2017 + media hub for carplay and android auto
  • 15% Tint on side 5% rear, 80% front windshield
  • 2018 red dash plaque
  • Color matched coolant tanks
  • Billet Technology catch can, washer cover, hood strut covers, shock brace cover, dipstick cover, AC line covers.
  • Color match strut tower brace.
  • BLASTLED Red hellcat head door projectors front and rear.
Exterior:
  • 2019 front grille pieces with new badge.
  • American Bros color matched trunk hellcat badge.
  • Redeye cat heads.
  • Ceramic Coat, CQuartz where stripes were removed.
  • Carbon fiber wrap on splitter, hood, spoiler (chip on splitter wrap)
  • Blacked out side markers and rear tail lights.
  • Carven 5” Black exhaust tips
  • IKON rear diffuser
Performance:
  • 180 t-stat
  • Forced Inductions supercharger spacer plates with thermal blanket installed on belly of supercharger to reduce IAT.
  • Killer Chiller with Drag Valve. Switch up, blue light on (cabin cool), switch down (drag valve) (12,500 miles). Gearhead fabrications 2 gallon auxiliary tank in front bumper crash bar.
  • Cox 9lb Lithium battery (CTEK lithium charger if sitting for 3+ days)
  • Tazer, double bypass, aux steering wheel buttons.
  • Turboguard (track only)
  • Carlyle racing Demon Springs
  • Drive Shaft Shop 1400hp rear axles.
  • Performance Development DIRS differential brace.
  • Spohn Red rear trailing arms.
  • Spohn Red Adjustable rear control arms for adjusting camber in the rear. Camber in rear set to -0.1
  • Bwoody end links.
  • Z26 brake pads all around.
  • Livernois Driveshaft (6lbs lighter than stock @ 28lbs)
  • 2017 dipstick (7.5qts w/full SRT filter)
  • Magnetic oil drain plug
  • Metco oil fill breather
  • Injected Engineering Gasohol twin 450 "276" Walbro pumps (1000rwhp capable)
  • Kenne Belle Dual plug and play boost a pumps. Boost reference adapter on supercharger lid for Hobbs switch which turns pumps on at 5psi.
  • Metco 3" idler set (tensioner and below supercharger)
  • Bwoody 3.0" idler for 2.4" upper
  • 2.85 ring for 93.
  • JBA Catless mids
  • Injector Dynamics 1300s
  • Brisk ER12S
  • Barth Tune (PCM/TCM) -- only go WOT when trans is set to Track
  • Diablo Trinity with Diablo PCM and 6 Tim Barth tunes (93 for 2.85 ring only, e70, e85, nitrous, and TCM for nitrous and blower only.
  • 2 Ethanol test tubes for testing pump ethanol before every single fill.
  • E85 for 80% on test tube and above. 21 degrees of peak timing.
  • E70 for 79% on test tube and below. 14 degrees of peak timing.
  • 93 WOT for 2.85 ring.
  • 877rwhp/920rwtq STD on Drag Radials 2.4 upper setup on E80.
  • 9.8@141 with a 1.49 60' on 305/45/17 ET Street R’s 2.5 setup 2018 season
  • x.xx@xxx with a x.xx 60' on 305/45/17 ET Street R's 2.4 setup 2019 season
  • Nitrous Outlet plate kit with 10lb bottle, bracket, purge kit, and warmer.
  • NOS mini progressive controller.
  • Nitrous Outlet center console buttons for arm, purge, and heat.
  • Setup for 75 shot.
  • x.xx@xxx with a x.xx 60' on Nitrous
Bad a** for a daily driver.
Nice
