Hmmm. ACR Challenger? My suggestions: Light weight, more power, higher redline, Demon Performance brake pads.
Lighter, just make it lighter! Don't screw with the powerplants.
Different bushings everywhere
Adjustable control arms (camber & toe - four corners)
Strut braces
Spring/shock tuned different, leave a street setting!
More stiff & adj sway bars
Demon Performance Rotors - four corners (makes rears two piece also)
Delivered with DOT 4 racing quality brake fluid
12" - 13" wide wheels - perhaps not 20" diameter
335/30 F 345/30 R or 345/30 x 4 or with wheel change 355/30 Viper rubber!
That would make them better, the most expensive is figuring out where to cut 500 or more pounds with lightweight materials.
K
Detroit
Afghanistan
AND maintain crash safety. I suggest the floor pan stamped in aluminum instead of steel. The Germans came up with the single-sided stamping machine that uses a template and a rubber membrane backed by tons of oil pressure to form sheet metal, instead of having to carefully craft a negative and positive metal surface stamping machine.
In fact, considering how heavy the chassis is, they could replace a lot of it directly with aluminum, replace front seats with lightweight racing buckets, and replace the stock hood with helium-filled titanium (that is a joke, it's light already.)
Aluminum block.
It's not hard to do, it's just maintaining the lives of people inside the car that is important. Who's the next Dodge Challenger buyer? Most likely the last Dodge Challenger buyer!
sad
Bartlesville
OK
Yeah... lighter lighter lighter...
FORGET ALL the other stuff until a light chassis is in place... And THEN start working on the lists above. Weight is the Challenger's biggest problem in this generation.
Same thoughts here. Weight period. 500 l.bs lighter, car would be even more unbelievable. Aluminum block? Com'on my 2011 Silverado pickup has one on a 315 horse engine! That should've been standard fare on an expensive perf. car a few years ago. Carbon fiber rims (Substantial weight savings, not just little bits---Ford did it). No power drivers seat. Aluminum floor stamping (and other hard/ body parts) great idea. At mass production level could be done easily and fairly economically. It could be done.
Oh and it should be named the Hellcat ADM.
motorhead
Ottawa
2019 Challenger HC Widebody
And for that reason I don't care enough any more. After seeing a WB Charger Daytona with a $30K ADM on it and a $200 charge for inflating the tires this morning - I am out. These cars have been taken over by greed.
The aluminum block motor already exists and is worth 110lbs.
And I know of a brake system in works to cut another ~80+lbs off...
Nice, that is twice what I save now. Keep it up, maybe sometime in a few track days this season I will need the shelf replenished ;)
There's a certain lab in Detroit that is doing its thing now, things move slow... : /
Demonic Cat
150 lbs of the nose of the car translates to better weight transfer, lower the rotating mass, sprung weight on wheels/tires are key places to focus weight savings on.
Don't forget this statement, it will come in useful in the future...
:cool:
K
Detroit
Afghanistan
Do you REALLY want these guys being attracted to it?
@Kat von Himmel - looked at that Ceika site, wow do they have some high rent items!
04Ram2500Hemi
Western
MT
2021 Ram TRX
Make it AWD and call it the SRT ACR Angel! [histerical]
K
Detroit
Afghanistan
Thread Starter #17
Yeah, 32,000 dollars for a full set of brakes mit der carbon rotors.
K
Detroit
Afghanistan
Thread Starter #18
They can't be $30,000 better than a Demon Performance set.
They have $5,500 wheels (each) for us also.
Now if I could just find that winning lottery ticket......
K
Detroit
Afghanistan
Thread Starter #20
They do offer a top-of-their-line cast iron 405mm front and rear diameter rotor kit for 4190 bucks, with everything included, including park brake compatibility, calipers, mounts, pads, stainless pistons, extra dust boots. That seems pretty good, especially with the cross-drilled-only rotors, since I do not like slots. Curious if Porsche has the tungsten-faced rotors locked up with patents, because that seems, by far, to be the way to go.
That seems rather hard to beat. I am not inclined to replace the well-proven Brembos, however.
