Going with 10.5 x 20 Replica wheel with 305/35r20
rdlsrt
Pearland
It's time for a new set of shoes. I had 275/40r20 Nitto 555R on the back, they lasted about 8k miles. Have the original Pzero Summer tires on the front, currently have 13k miles on the car.
I have decided to go with 275/40 on the front and 305/35 with 10.5 x 20 replicas on the back, Firestone Firehawk Indy 500’s all the around. More than likely will use Mopar stage 1 springs on the back only.
Anyone have some pictures of the 10.5 x 20 wheel with 305’s on their Challenger?
Wanted to do everything (wheels and tires) at Discount tire but they don’t sell that tire. Looks like it will be cheaper to purchase the wheels from Discount and have Firestone mount them, Discount wanted $176 to mount and balance the 4 tires (that seems steep).
Once I pull the trigger will post some pictures. With a 35 in the rear I think lowing it is a must.
Heminized
New Smyrna Beach
2015 Challenger
Let me know if you need more angles.
USMC Gunny
Tucson
2016 Hellcat
What do you mean Discount tire don't sell those tires. I just ordered the same exact setup as you last Friday. The sales guy called Firestone for pricing. I had them price match the rears at 240, Firestone told discount tire that they were 291 the first go around.
Tires and wheels are supposed to be here today.
Heminized
New Smyrna Beach
2015 Challenger
JRabq
rdlsrt
rdlsrt
Pearland
rdlsrt
rdlsrt
Pearland
I called and they told me it would have be purchased from a 3rd party and i would be better off purchasing from Firestone. Direct quote... I am in Houston, 275 fronts and 305 backs... $976.02 drive out... Wheels I would purchase from Discount.
USMC Gunny
Tucson
2016 Hellcat
Heminized
New Smyrna Beach
2015 Challenger
Those look like ECSs, did you need spacers to fit? I have PKAD HR5 10.5s with 25 mm offset, Cont ECS 305/35/20 on rear of 2017 ChallengerHC.
I did not use Spacers. My rears are PKDesign HR5 10.5" Hellraisers with the same tires as you. I did not need to use any heat, but the inner fender well is slightly warped from exhaust towards the tire....no rubbing, but a very tight fit. I imagine I will at some point have to use heat to pull the inner away from the tire....
Looks good, do you have a side angle of the car? And have you lowered yours?
I used Eibach Pro's on all 4 corners to lower.
Sylmar
2019 Hellcat Challenger
Looking solid guys !
I’m putting that setup on my rear tomorrow. Any rubbing issues?
Those look like ECSs, did you need spacers to fit? I have PKAD HR5 10.5s with 25 mm offset, Cont ECS 305/35/20 on rear of 2017 ChallengerHC. I trimmed liner, heat gun too and still tight enough that I use 1/8" spacers. All good now with that.
so you had to run a 1/8” spacer.
JRabq
I am not sure it was mandatory. It was very close and I thought I heard a few random rubs without. So for peace of mind i put the spacers on. The wheel/tires still sit great at outer edge, and no issues of any kind with spacers on.
I have the firehawk indy 500 305/35 20 on 10,5 on the rear of my car and the front is 275/40 20 indy 500 absolutely love them so much better then the pzeros
Good to know
Heminized
New Smyrna Beach
2015 Challenger
No sir...So far so good. :)
