Electric steering
Billet Train
Toledo
Can a power steering car be changed over to the newer electric steering rack? I understand the elec. steering cars have different modes, not really concerned with that. Just wondering if you put power to the rack will it will work. Thanks MIke
The big concern is is the electrical connectors there ? And how do you activate it?
Billet Train
Billet Train
Toledo
I think the brains are part of the rack. So if you run power to it..........
I'm not sure I have looked at one yet . I was assuming it required some kind of signal from a module with in the car somewhere.
Billet Train
Billet Train
Toledo
you may be right. I was hoping it would be as simple as installing the rack and powering it up. And maybe the rack has a default mode as long as it has power.
When I do my next oil change I will see if there is any unused electrical connectors down there .
Billet Train
Billet Train
Toledo
sounds good
Wondering if FCA tied the steering controller into the anti-theft / anti-mod system, like the freaking gas tank, center stack, and AC controller....
Billet Train
Billet Train
Toledo
I think I can get my hands on a 2018 392. For some testing.....
What's the first year they went with electric assist?
On the hellcat ? 2018 demon and wide body only . 2019 and up all hellcat variants.
392 cars had it starting in 2011.
Thanks. Thought it was only 2019 and up hellcats. 392's had it since 2011? Surprising.
Yeah I thought it was wierd that 2015-2018 hellcats got hydraulic power steering when pretty much everything else had electric power steering.
My 2016 Camaro 2SS has electric power steering.....it's pretty cool. Increases resistance with speed and stuff. :cool:
Slows2k
Murfreesboro
2018 Challenger
S2000’s all had EPS, and that was 20 years ago.
My 17 Hellcat had no extra wiring for the EPS rack. I would count on the EPS being tied to everything on the CAN bus, as you can adjust the steering weight through the SRT menus.
Billet Train
Billet Train
Toledo
Thread Starter #16
Ok well........ The 2018 and up rack, absolutely has to have more than just a power supply.
Confuzed1
Go Pack Go
May want to double check on '11's having electric steering. I bought a 2011 SRT 392 brand new, and it had hydraulic steering. Not a big deal, I personally have not heard of any Challengers having electric steering until either 17 or 18....
No idea what the electric steering gets its signal from.....almost has to be either steering shaft or wheel position?? Seems like something so important should be its own stand-alone system and not go through the ECU with 1000 other things...now I'm wondering how it works! lol
Slows2k
Murfreesboro
2018 Challenger
Most EPS systems use a steering angle sensor, and some type of steering torque sensor. Engine speed and vehicle speed are typically inputs used to adjust assist.
You are correct . I went and checked it was the 5.7L cars that got the electric power steering. Not the 6.4 cars . My bad .
My 2015 SRT had it.
