Could not get front end into alignment
AlleyCat
Oro Valley
16 HC Challenger
Alignment shop recommended SPC adjustable ones. Are they good? Or do I have to go with AAD? 400 vs 850 in cost. Please advise.
What is the problem? The toe is adjustable and easy. If it is Camber, what are the readings and/or are there problems?
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
He said the bushings on the upper control arms are old and bad. I will ask about the camber, caster and toe.
Then your Camber/caster is affected. It may be or will be loose. Okay. Easy answer, it costs more but those AAD arms are excellent replacements. Those Spheriflex bushings are the shit. Then that alignment is easy for them.
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Gulp. With shipping 847. Done!
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Ok. Lower front control arms. Choices? Which should I buy?
Thanks
OEM
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
Just orders oem lower front and have on order aad front upper. Thanks to you all.
Your going to like your new front end a lot.
