Cant get the hc tires to hook up
TOMMYJR9
I have 2 2016 Dodge Challenger HC
One with stock summer tires & the other HC has nitto's drag Radials (in the rear) I cannot get neither one of them to hook up at the dragstrip any suggestions please advise . Thanks
LonestarHellcat
There was a guy that got in the 10's with drag radials. Are you properly warming up the tires beforehand?
HellcatFan
What were your 1/4 mile times?
HellcatMike
The Nitto NT555R 305 should work good on the Hellcat.
TOMMYJR9
TOMMYJR9
I have them on the rear :(
TOMMYJR9
TOMMYJR9
1/8 mile & was not good
LonestarHellcat
Do you have any vids from the races other than those burnouts?
TOMMYJR9
TOMMYJR9
HellcatFan
Did you check your tire pressure to make sure they are not over inflated?
TOMMYJR9
TOMMYJR9
26 lbs
HellcatFan
TOMMYJR9
TOMMYJR9
HellcatFan
Try lowering them down to 20psi. Depending on the track and temp I've seen guys run them as low as 17 or 18psi.
TOMMYJR9
TOMMYJR9
Ok
HellcatMike
I agree with HellcatFan tire pressure is way too high.
TOMMYJR9
TOMMYJR9
Thread Starter #17
Last night, on stock tires
HellcatMike
Really great 1/8 mile time.
TOMMYJR9
TOMMYJR9
Thread Starter #19
HellcatFan
I would agree anything in the 7's are good numbers.
