Boost A pump
Plant City
2019 Challenger
I have a basic bolt on build running on 93 octane tune. I am interested in getting a Kenne Bell Boost a Pump for better fuel delivery. I am wondering if anyone has an accurate wiring chart for this application. I am purchasing KB Part KB89073. Thank you.
FFBOS
Mount Prospect
2016 Hellcat Charger
You don't need it with 93. If you record logs at all, you will see where your duty cycle is at. If the pump is tired from years of running hard on that setup, replace the pump.
bc_hellcat
Plant City
2019 Challenger
You are correct I really dont need it but I am getting some symptoms, which appear to be loss of fuel (quick hesitation at high rpms, boost. My tuner says a BAP wont hurt so I figure more fuel would fix the slight hesitation I get.
bc_hellcat
Plant City
2019 Challenger
Also I havent had a tune long and havent been running it hard (racing, etc.) at all. So it really shouldn't be worn out. low mileage as well.
A BAP won't necessarily hurt, but it may hide the symptoms of a failing stock pump. You don't need any more flow than a good stock pump provides on 93oct. I think the concern should be that a BAP is a band-aid and when this one gets ripped off - it'll hurt a lot.
I'm a BAP fan, you just don't need one.
bc_hellcat
Plant City
2019 Challenger
Thank you. I appreciate your input and am glad I posted before I purchased one. You think a stock Hellcat Fuel Pump is sufficient. I am at 15psi and right at 860 whp? Thanks.
FFBOS
Mount Prospect
bc_hellcat
Plant City
2019 Challenger
Thank you very much. So
I would use this as a secondary I pump and keep my stock Hellcat pump? Also, will be 1050 injectors be adequate to handle the 2 pumps? Thanks.
FFBOS
Mount Prospect
No, you pull out the pump housing on the driver side of the car. The pump is inside of a white plastic tray. You can pull the old one out, and put this one in. Plug and play. This video shows how to get it out.
bc_hellcat
Plant City
2019 Challenger
Thank you for clarifying that. No worries about the additional heat it will generate?
FFBOS
Mount Prospect
No, it's the same exact pump that is currently in the car.
bc_hellcat
Plant City
2019 Challenger
Thank you.
I do think a stock pump is enough. Someone like @Speedy! that has really pushed the limits of pump gas can help more.
bc_hellcat
Plant City
2019 Challenger
I appreciate your insight. Thank you.
2 door Challenger HC come apart the same way as the 4 door Charger? sure looks easier to do on a Charger then a Challenger , just getting in the back seats a chore let alone working back there lol
GREAT info and links FFBOS, thank you!!
Just an FYI
AAD Billet Hellcat/Demon Boost Reference Adapter - AADBRA
This a complete bolt in adapter to run a boost-a-pump, boost gauge, or any use of boost reference. NO MORE REMOVING, DRILLING, AND TAPPING your supercharger lid. Comes with billet aluminum adapter, viton o-ring, and stainless steel bolt, everything you need to easily add a reference port. These will fit all year Hellcats, Demons, and Redeyes.
https://highhorseperformance.com/aad-billet-hellcat-demon-boost-reference-adapter-aadbra/
Linda :)
bc_hellcat
Plant City
2019 Challenger
Thread Starter #17
Awesome. Thank you ma’am.
I personally run the jms bap its totally plug and play and no boost refrence is needed so no cutting of any wires at all ,when I installed it on my stock hellcat pump my pump average was 90 psi I absolutely loved it ,if your fuel pressure is dropping to less then what is commanded then its not right if it commands 80 psi and your dropping to 70or less psi ,im sorry but its not right and your injectors get smaller and the car is under performing ,I now have it attached to my dual pumps gotta love knowing your fuel pressure is on point
bc_hellcat
Plant City
2019 Challenger
Thread Starter #19
Thank you. Can you send a link to where you got the pump please.
I bought mine from curt@dusteroff tuning
