Batteries
The factory battery weighs around 44 lbs. That isn't what I was asking. Was asking what the new battery weighs. The listings are not always accurate and this battery is bigger then the one I have
Oh like 17lbs.
Thread Starter #43
Thread Starter #44
Cool.im not pulling that sucker out to weigh it.
Used to be allot easier "in the old days".
Strap, electric plug in, post clamps and bottom clamp.
Used to be a bottom clamp " in the older cars.
I get it why I asked if you had weighed it. Mine is smaller then the stock battery and is 14.3 lbs so figure 17-20 lbs for this one being the stock size
Interestingly having some weight in the trunk seems to be the move in these cars.
Removing weight off the front is where it's at.
I'll try to remember to weigh it when I get home today.
May not be in the mood to check today (dentist appointment after work).
bout time ya got that tooth taken care of...
And it was up front near the grill, not buried in the trunk, under a seat somewhere or right up on the firewall !!
That's what I'm hearing at the dragway. I guess the exception is for track racing which DGatzby does. Probably better for everyone else to just save $.
-30 lbs is good front or back. It maintains a weight balance L-R back there also.
