New personal best!
Awesome run, now that's smokin'!
Bummer about the axle :(
Congrats!
You're lucky you have some axle poking out of the carrier... trying to get a piece out without anything to grab on to is a PITA!
U
Thread Starter #43
Congrats!
You're luck you have some axle poking out of the carrier... trying to get a piece out without anything to grab on to is a PITA!
Thanks! Popped right out, I'm not sure I'd call it luck lol. More bad luck than anything that night
7 Second Best E/T
great job buddy. in my personal experience. The redeye and Demon axles break just the same. I've had the DSS level 5's in my car for 3 seasons now without any issues. Multiple 1.1 60's countless 7 second passes. buy once cry once.
U
Thread Starter #45
Thanks! Nowhere near as fast as you, but hoping I can eventually get in the 8s with the 2.4 IHI. That's the way I look at it - hopefully won't have to worry about axles ever again. Just everything else 😆
Thanks @Speedy! ! Had no idea what to expect with all of the work that I've done to the car this time around. I would have settled for a 9.5. This car continues to surprise me. The gains seem to be a lot more than I would have thought.
And unless my boost calculation is wrong (not sure if it will calculate correctly with 2 bar sensors) I was only making 17.75 lbs of boost
Your 2 bar MAP sensors are probably pegged, mine in the past when running a ported 2.4 blower yet they top out right around 17.75 like you are seeing. Your probably making more boost then you think. You need to upgrade your 4 Map sensors with 4 new 3 bar units. I may have a set of 4 from a Redeye blower, let me know if you need them and I will look for them.
With those times, I would guess that pretty much all OEM parts are dog crap! :ROFLMAO:
Great job!!!
