IC Chiller install & review
U
Thread Starter #421
No visual fluid loss in the tank or on the ground/the belly pan, just around the fitting but a leak is a leak.
U
Thread Starter #422
HEL performance has good fittings too that have never leaked. Very disappointed with vibrant
Katy
2018 Trackhawk
THANK YOU ALL FOR THE TIPS!!!! 12-point crows foot on the way. I def don't think I did a 1/4 turn.
Katy
2018 Trackhawk
1/4" turn at least. I have the same exact fittings and they still leak no matter what. They might finally be ok. I don't think the temperature fluctuations help
Yeah, I've been running it on several drive cycles, been dry until recently. And it seems it's mainly the "cold" side ones that are leaking. Hopefully once I torque them all they will withstand the temperature cycles.
U
Thread Starter #425
Good luck trying to get a crows foot and hold the other side. Not impossible but difficult. Use 2 huge open end wrenches, finger tight, mark them, and then do a 1/4 turn. The 1/4 turn has worked amazing for me for fuel. You can definitely over tighten them as well
