2016 challenger m6 clutch.
Ridgeland
SC
2016 hellcat A8 and 2016 M6
My sons clutch is on the way out it's street and sometime track....He's like me the last time replace a clutch was a Muncie 4 speed. So you have to have a clutch, release bearing and sometime the flywheel. So what I'm asking what would be a good clutch that wont break the bank and other than the clutch what else is needed. any help will be greatly apricated.
I haven't done mine yet, but when I do, it will likely be a McLeod RXT 1200, solely based on others experience here on the forum .
McLeod or mantic. @16GoManGoHC2 has a mantic clutch and flywheel for sale right now, just need an HRB. I used a RAM, it was good but you need teflon tape on the HRB fittings or you’ll have a nightmare bleeding it. Also a pain shimming their HRB. Stockcstyle HRB is the way to go, which mantic and McLeod use
Also, anyone else think of Highlander every time you talk about McLeod clutches?
I have a BBG twin disc with aluminum flywheel and HRB I can sell. Needs new friction plates but is otherwise in great shape.
Friction plates are just Miba B10000A which are resold in many places, Ram clutches for one.
BBG is a private label RAM clutch, exactly the same one. Only difference is BBG pre shims/adjusts the HRB for you. Other than that it’s the same clutch, flywheel and HRB, as confirmed by RAM. That’s why I went with theirs, a LOT cheaper and BBG
Oh, and theirs is black not red lol
That's what I suspected, but couldn't find all of the parts available from RAM. Thought maybe the pressure plate was custom. The flywheel, HRB, floater and friction plates I was able to identify in their online catalog.
