Brake Pad Longevity - 10K miles?!
Erie
2021 Challenger Hellcat
Folks -
I have a WBRE with 10K miles on it. Never tracked, no stop and go traffic, minimal hard braking in curves or otherwise. At the dealer today they told me I need new brakes to the tune of $6,700! I've had Brembo brakes on several cars before and acheived at least 30-50k miles. At the dealer they cited that brake pads are a wear item, which I get. She said "driving habits" at least 6 times. Thing is, I have many high performance cars and my "driving habits" don't result in this type of wear. Is this just a suck it up buttercup kinda thing and expect to pony up this cash every 10k miles?
2ndgen
Orem
Dealers lie. Measure the pads and rotors yourself.
Highly unlikely you need either pads or rotors at a mere 10k miles.
Pads should last 20-25k or more miles, rotors nearly double--unless you're tracking.
Also the fact that they quoted you $6700 for it... that's more than outrageous, that's double what others have posted for dealer quotes--which is already way too high.
Sounds like BS to me, I'd go to a different shop/dealer ! I have 13k on mine and they are about at the 1/2 way point. Unless you beat the crap out of the car all the time, I can't imagine them being done in at 10k.
Narrow body charger here.
41k miles on original pads and 2pc rotors. With coming up on over 5k miles of Drag & Drive towing a 1300lb trailer with it. I've probably got over 50 passes as well on them.
2016, 23k on mine, original pads with 50%+ life still on them and I have done literally hundreds of 60-130 runs and 1/4 mile passes.
Folks -
No way you need brakes @ 10,000 miles..(even with spirited driving)...and the price they quoted you...obscene...get that car outta there NOW
Folks -
Are you able to post pics of the faces of your rotors, if they are truly that bad, we can easily tell from just pics.
Try to include at least one of the grooves from a slight angle so we can see how much of the groove is left. (Which is a good indicator of how much wear you have, but not definitive)
If you're able, as said above, pull a wheel off and measure a rotor thickness.
They start at 34+mm and don't need to be replaced until <32mm, unless they are also heavily grooved, which isn't common on these cars.
As for pads, they are super easy to replace given the mono block caliper design.
The rotors are easy to replace as well, but require slightly more knowledge, experience and tools, but really, don't be put off by that, there is a bunch of help here, and if you're willing we can get you through it.
Even having to buy parts and tools, you'll be FAR ahead of that quote, even IF you do need rotors, but likely JUST pads, even if that.
I'll post up starting pad thickness and suggested min tomorrow, I forget off the top of my head, I think they start at 16mm???
Driving habits make a difference
No way. Unless he has his left foot riding the brake pedal. Let’s see the pictures.
Bowlerguy92
Get a new dealer
rayzazoo
Hellcat
Folks -
I have a WBRE with 10K miles on it. Never tracked, no stop and go traffic, minimal hard braking in curves or otherwise. At the dealer today, they told me I need new brakes to the tune of $6,700! I've had Brembo brakes on several cars before and achieved at least 30-50k miles. At the dealer, they cited that brake pads are a wear item, which I get. She said "driving habits" at least 6 times. The thing is, I have many high-performance cars, and my "driving habits" don't result in this type of wear. Is this just a suck it up, buttercup kinda thing and expect to pony up this cash every 10k miles?
The dealer wants your money, and most of it will be for labor/upcharge for the Mopar part #.
Alternatively,
~$2000 (~$1350) for better/lighter aftermarket fronts on OEM hats and rears (Paragon, GiroDisc, DBA), OEM Brembo pads, brake grease
(e.g. Paragon fronts $750 replacement rotors for OEM hats, $950 Paragon rears (can also find OEM rears for $200-300 through a non-Mopar source), $300 Brembo front/rear pads, $13 grease
~$250 Low-profile jack and stands
~$200 mechanic toolset
~2-4 hours of time, depending on your beverage of choice
free YouTube
And a quality tq wrench
What is the best option since this thread took off?
Factory 2pc fronts on a 2018 for reference?
It don't autocross but it does trap 140+ in the 1/4
I think you guys may have scared him away.... :confused:
Really. Pictures of a rotor for your friends to help before spending $6k would be a good idea.
rayzazoo
Hellcat
Alternatively,
free YouTube
Brake Parts Total: $1008.17
$725 - Paragon Front Rotors - https://paragonbrakes.com/15-7-front-rotor-rings-21-charger-challenger-srt-hellcat/
$129.98 (x2 $64.99) - ACDelco Rear Rotors - Part# Gold 18A2677 - https://www.summitracing.com/parts/...B2IACWCK8CSbk6Akd1kQZYUY5YlH8SWdmml6PQ0I0qRuK
$81.78 - Brembo P37018 Front Pads - https://www.summitracing.com/parts/...AAwZjS7dcTjBbU53rRHtqA4uPBlih8yxoCgS4QAvD_BwE
$71.41 - Brembo P11024 Rear Pads - https://www.summitracing.com/parts/bbo-p11024?rrec=true
2ndgen
Orem
It's even more highly unlikely that he needs new rear rotors, probably not even rear pads.
I'm at 52k miles. I've changed front pads twice, front rotors once, meanwhile my original factory rear pads aren't even 1/2 way done, let alone any significant wear on the rear rotors.
So you can probably knock that estimate down by $200. Call it $810, worst case scenario--but if his rotors really are worn at only 10k miles of street driving something else is wrong.
And we will never ever know...(the rest of the story)..
For a $6,700 question, I would check back. He has been a member since ‘21. Maybe just a covid inspired something member and not serious.
This very closely mirrors my brake usage at 53k miles...I replaced the rears anyway because I already bought the pads and everything was apart, but my mechanic said there was a lot left and didn't need to change. I've only ever done burnouts(hundreds of them lol) by footbraking and overpowering the rear brakes too, never have used the line lock in 6+ years.
